Question about GE WJSE3110A Top Load Washer
Will not agitate - GE WJSE3110A Top Load Washer
  • 6,784 Answers
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cuase this dissruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Posted on Sep 06, 2009
Will not spin or agitate
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Nov 26, 2012 | Maytag Legacy Series Top Load Washer
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Jan 11, 2010 | Maytag Washing Machines
Everything works but the agitator
The small plastic pieces that are located under the agitator center cap that grip the agitator and turn it during the wash cycle are worn out. They are called agitator dog ears or clutch dogs. They must be replaced.
  2. Remove the fabric softener dispenser, if there's any, by pulling it off the agitator top. cf99d03.gif
  3. If no dispenser is installed, insert a flat screwdriver between the agitator and agitator cap. Pry the cap off the agitator then remove the upper part of the agitator. cae2ce0.gif
  5. Use a socket wrench with extension or nut driver to remove the stud and seal holding the agitator to the shaft. 96cc7e9.gif
  7. Turn the agitator mover over on your palm. The cam and agitator dogs will come out on your palm. Pay attention to how the agitator dogs are installed. Remove the worn agitator dogs and install the new ones. c8eb889.gif
  8. If the agitator dogs are not worn, check the agitator shaft. Remove the round rubber seal off the top of the agitator and remove the agitator by lifting it straight up. Call up service if the shaft is worn. ca89530.jpged86a35.jpg
  9. Reinstall the agitator. Rotate it until the grooves on the agitator matches the grooves on the shaft then push the agitator down.
  10. Place the round rubber seal in the groove on the top of the agitator. 5314b95.gif
  11. Turn the agitator mover over and carefully insert the cam and agitator dogs up into the agitator mover until it stops. c55998d.gif
  12. Carefully turn the agitator mover over in upright position.
  13. Place the agitator mover with the cam and dogs over the agitator, lining up the tabs. The cam has a cut-out and tabs across from each other. The agitator has tabs across from each other. All of these must line up in order for the cam to slide down on the agitator.5f7e245.gif
  14. Push the cam down until the tabs snap together.
  15. Put the upper part of the agitator back.
  16. Using a socket wrench with extension or nut driver, insert the stud and seal through the agitator into the shaft and tighten it.
  17. Push the barrier cap and seal down into the agitator mover all the way. Make sure the round gasket is in the groove in the barrier cap. The barrier cap must be pushed down past the holes on the mover to allow the liquid from the dispenser to flow.
  18. Press down on the fabric softener dispenser or cap until it is all the way down on the agitator.
Nov 30, 2009 | Kenmore 24622 Top Load Washer
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
Agitator doesn't agitate - kenmore model 110
how old is the machine? agitator dogs in agitators have only been used for the past 15 or so years. sounds like you need to take the agitator out and replace the 4 dogs in the top of the agitator. not a costly repair.
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
My washer stopped adjutating but it drains the water out what is the problem
The agitator is driven by a couple of different methods. The first is the agitator is spline and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling.
If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Aug 07, 2009 | GE Washing Machines
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
-no agitation
Hello
Welcome to Fixya
My name is Huum,
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 10, 2008 | Maytag PAV2300 Top Load Washer
GE WJSE3110A Top Load Washer Logo
106 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
