Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator lite doesn't work
It's not the bulb, it's not the switch at the bottom of the door.
Is there anything else I should check before I call a repairman?
  • 5 Answers
This happened to me once... Unplug the fridge, then using a screwdriver, gently lift up on the metal "tab" inside the light socket. This tab is the "hot" conductor, and sometimes can get mushed down so it doesn't contact the base of the bulb. Again, it's the "hot" conductor, so be sure you UNPLUG the fridge before trying it!
Posted on Jul 14, 2009
WHIRLPOOL WBM35 IX LIGHT NOT WORKING
Check door switch lite will have a switch on door can maybe just a wire off
Jun 29, 2015 | Whirlpool Refrigerators
Lite bulb in freezer not working, put a new bulb in still not working
Unplug it.
There is usually a switch that gets frozen in the closed (door) position.
Try looking in the freezer, front and center, ceiling area.
If the switch moves easily, then it could be the socket.
If it is iced up, wipe it with a warm wet cloth in the same direction that the door opens and closes to get it to spring back.
Plug it back in.
If that doesn't help post a model # and I'll continue the walk through.
Feb 23, 2015 | Amana ARB2217CSR Bottom Freezer...
Light not working on bottom freezer
Probably a bad door switch. Turn off the power, pull out the door switch, connect both contacts together with a jumper wire (bypassing the switch). Light goes on bad switch. Light stays off, check bulb or bulb soket (expecially center hot pin, they tend to flatten out over time and will not make contact with the bulb).
Aug 28, 2014 | Refrigerators
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Light wont shut off, heats up to 88 degrees
Most times this is a defective fresh food section door light switch located in this photo as location number 609. Click Here=> PSC23NSTESS Fresh Food Section I am going to send you the service manual for your model and the information that explains how to change the switch is on page 19. If you do not already have the new free Adoobe Reader installed on your computer click here=> Adobe Reader X (10.1) Just make sure to uncheck the items not needed during the download. There also could be another problem related to the mother board that can also keep the light on while door is close but not likely. The part number for the light swirch is=> WR23X10175 Light Switch Information on how to test the switch is also on that page. Until we have repaired the problem please unplug and remove the lights because this heat will keep the refrigerator running and possibly melt the plastic housing holding the bulbs. Click here for the=> GE Artica/Profile Service Manual
Here is another page with information and wiring diagrams=> GE Artica/Profile Technical Information
I will be here to assist you if you have any questions so feel free to let me know, Thanks Sea Breeze
Please rate this solution and as always Thank You for using Fixya!
Jun 21, 2011 | GE CustomStyle PSC23NSTSS Stainless Steel...
I cannot get the lite inside the refrigerator to lite, have tried new bulbs, no luck
bulbs need to be supertight to make connection,almost too tight....keep turning till it comes on-it will.
Mar 10, 2010 | Refrigerators
Why dont the lites in reftig work --I replaced
Good day,
If both lights went out at the same time, then it is normally the light switch which is located front and usually top of fridge compartment.
First, test the old bulbs in a lamp ect. if O.K. then you will have to change the switch.
It pries out, but is usually broken in the process.
Do this with the machine unplugged, since the power to the switch is always hot electrically.
But before anything else.......
Make sure the new bulbs are snugged in well. They form a moisture seal, and must be tight.
Dec 31, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My fridge has decided that the light in the top portion is going to stay on all the time. It got so hot that the light cover melted. I've taken out the light bulbs and everything else works fine. The door...
heck you door alignment to be sure when the door closes it is hitting th lite switch and turning the lights off. sometimes it is necessary to put shims on the door hinges to raise the door to cause it to hit the switch properly.
Jul 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
