Question about LG WM-1832C Front Load Washer
The bearing is getting noisy when the drum turns.
  • 92 Answers
These will have to be replaced,and this is a pain to do.?
Posted on Jul 15, 2009
Servis 1200 very noisy in spin modes. Inner drum seems to be very loose and wobbly. Noise sounds like a roller with flat spots running on the drum, or a very bad (failed) bearing. Machine is 12 years old,...
the bearings have gone, if the drum can be split, remove complete drum and replace bearings, if you dont think its something you can do, dont attempt it, but to be honest, its realitivly easy
Sep 09, 2013 | Washing Machines
Kenmore oasis washer noisy when spinning
Hi, your probably right about the bearing its usually hard to tell untill they have compltely gone have you tried turning the drum by hand to see if it turns smoothly if it does then it could be the motor thats noisy both can be replaced but the drum bearing is a nighmare trust me you need pullers and its hard work.
So try turning the drum by hand and see if you can feel any roughness or catching this would tell you if the drum bearing has gone.
Let me know the outcome ok
May 01, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Noisy drum bearing also play on drum
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Apr 30, 2011 | Washing Machines
The drum is very noisy when it turns and spins? There is no rattle but it sounds very raspy.
Sounds like the main drum bearings have failed.
Remove rear panel, and remove the drive belt.
From the front open the door ,and spin the drum by hand,
If it feels rough, or is rumbling at all, then the main drum bearings have failed.
If no obvious noise, then it could be the motor bearings that are noisy.
Hope this helps.
Dec 09, 2009 | Bosch Washing Machines
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Drum is noisy when turning and it looks like it is slipping.
It is your drum bearing. There is a bearing on the drum, and it is probably woren down.
Nov 19, 2009 | Whirlpool Dryers
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Noisy Servis M9503S
    Hi.
    Remve the belt, and turn the drum by hand, if it sounds rough or is noisy, then yes the main drum bearings have failed.
    It is a DIY job , but can be expensive, probably cheaper to buy new washer if it is more than 3 or 4 years old.
    Nov 22, 2008 | Hoover AAA140 Front Load Washer
    Washing machine really noisy on spin!
    Probably main drum bearings worn
    If you turn the drum by hand and it feels rough or noisy ,then definately bearings worn and noisy.
    Nov 19, 2008 | Washing Machines
    Wm noisy
    drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
    Sep 25, 2007 | LG WD-16110FD Front Load Washer
    LG WM-1832C Front Load Washer Logo
    209 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
