Question about Daisy Toys
Where do i oil the gun - Daisy Toys
    Problem Solver:
  • 14 Answers
On all the Daisy BB rifles I've seen (and on the Model 111 I've had for almost 40 years), the oiling hole should be on the top of the barrel, with the words "Oil Here" stamped around the hole. Hope this helps.
Posted on Aug 07, 2009
My gun has no power and seems the piston seems to chug when I pull the trigger
Have you oiled the gun? Take some light oil, gun oil or 3in1 oil and oil all moving parts, including the piston rod . Oil the barrel a well.
Jun 08, 2014 | Crosman Nitro Venom Air Rifle .177 Cal....
How do you oil a round head framing nailer model # FR350A, what is the correct procedure for oiling the air inlet??? How many drops? What kind of oil? How often can it be oiled?
Next time that you are in Lowes/or other contractor store, notice that there are several brands of nail gun oil sold in the tool department. Bostitch, Paslode, Campbell Hausfeld just to name a few brands of oil that are sold. You can buy any of these or just buy non detergent motor oil. From five to ten drops in the air inlet twice a day depending on use. For best lubrication however, purchase an inline oiler and install at the gun or close. Here are two examples: Plews/Edelmann Inline Tool Oiler 41101 or Porter-Cable PF254 (there are many other brands all costing about 10 to 20 dollars). These oilers hold a few days supply of oil and enter the gun in an oil mist rather than drops all at once. No matter what method you use to oil your gun, every now and then store the gun hanging with the air inlet pointing down so that the access of oil and water (debris) will run out of the gun. Every time that you connect the air line, debris that happens to be in the hose will enter the gun. After long term use of the gun, there will be an accumulation of debris in the gun that will begin to effect the action of the gun.
Oct 08, 2011 | Porter Cable FR350A Factory Reconditioned...
Product NR83A2. Lubricate is coming from the trigger and exhaust cover. The nailer is new and I put lubricate in the gun prior to placing the air plug on. What is the best way to drain the excess...
Excess oil will eventually be consumed /blown out of gun, however if you store the gun over-nite with air inlet pointed down, gravity will assist. I find that oil /water will accumulate inside gun especially if compressor is passing oil and/or weather conditions cause system to produce lots of water. Majority of guns that come in for repair suffer from a lack of lubrication. Several drops at start of day should be ok for oil lubricated compressors and maybe more for oil-less. If oil drips out of gun overnight (if stored as stated above) then reduce drops. What actually shortens life of gun is debris that enters gun from handling and that enters hoses during transport. Before connecting air hose to gun (with hose under pressure) momentarily connect a spare quick connect fitting and blow debris out of hose.
Mar 16, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
My Dewalt framing gun blows compressed air thru the nailer nose? Thx Kurt
Rebuild gun with gasket repair kit.
How it works: Compressed air enters through air hose and fills gun cylinder.
When trigger is pulled, air inside cylinder rushes out and pushes firing pin that shoots nail.
Inside the gun there are gaskets that seal the nose, the trigger and the cylinder head.
When any of those three gaskets fail, then air starts leaking.
Putting a few drops of nail gun oil into gun before connecting hose is supposed to protect gaskets.
But everything wears out, and sometimes folks use 3-in-1 oil instead of gun oil.
3-in-1 is detergent type oil and will cause gaskets to fail.
Another thing is guns that are not used frequently and gaskets get dry.
Putting in a few drops of oil and then immediately shooting gun will cause gasket to fail, because gaskets are still dry.
Best to put in plenty of gun oil, and let oil go down into gun for a few hours before connecting hose and shooting. Even so, nail guns are designed to be used every few days with continual oiling.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Tools & Hardware - Others
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
Nail gun will not shoot and air is exhausting out top vent all the time.
Oct 21, 2010 | Garden
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Do I need to oil this gun during use? I have many other guns that require oiling and have a stamp on the gun that says do, tho I do have another senco trim gun that I know is oilless. Do I need to oil the...
yes, squirt oil in the tool 2 times daily depending on use. do not oil the nails/pawl area, it only collects dirt. About 6 drops in the air fitting should be fine.
Nov 13, 2009 | Senco Air Tools & Compressors
Bostich nail gun plumger not retracting
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
Nov 27, 2008 | Heavy Duty Stanley Bostich Heavy-duty...
How do you oil a nailer?
first off some nail guns do not need to be oiled, but the gun you have listed does need to be oiled you just drip a few drops of oil in the hole where the air hose connects to the gun, but make sure that you are useing the right oil make sure it is pneumatic oil for air nailers. the gun should have came with some oil if it was bought new if not you can get the oil at Lowes, Home Depot, or any other home improvement store
Sep 30, 2008 | Stanley Bostitch F21PL Nailer
Toys Logo
229 people viewed this question
Top Daisy Toys Experts
Tom Chichester
richie46
Are you a Daisy Toy Expert? Answer questions, earn points and help others
