Emachine dead only fans and constant orange light work.
    Problem Solver:
  • 8 Answers
If the power supply is a Bestec ATX-250-12e then most likely the power supply has killed the motherboard. You will have to replace both the power supply and motherboard.
Posted on Jul 20, 2010
  • 4,806 Answers
Does the orange LED go green when the machine is working? if so take out the system ram (memory) clean the contacts and the slots, reseat the ram and try to boot up.
Good luck.
Posted on Jul 14, 2009
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
My emachine T6216 starts up with fan on high speed but that's it; no screen nothing. I have reseated RAM and cleaned. I swapped out the power supply and it was the same. I added a video card and still...
E-machines won't start
is there an orange light on the on/off button? if there is that means *********** board just went bad, check the capacitors. Capacitors are an inexpensive little component on a PC motherboard, but they can be a costly headache for manufacturers when a whole bunch of them go bad
you can not always detect them but check and see common in a few dell models but the high speed on the fan tells me that's what it is
Apr 28, 2010 | E-Machines eMachines Desktop PC
I have an Emachines 620 and it wont boot up. The 3v Battery was dead so I took the one out of the remote but its still not booting. DVD drive open and closes but CD drive doesn't. Fans are running and...
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Mark
Oct 26, 2009 | E-Machines (306785) Motherboard
When i turn my computer on the monitor go out and flashes and the orange light on the front of the computer stays lit and the fans run constant
Check your cables first. Reseat your connection from cpu to monitor. and check power source and cable.
If not reseat or clean the edge connector of your ram module with soft eraser. But first shutdown your unit and unplugged to power outlet.
Hope this helps
May 02, 2009 | E-Machines eMachines Desktop PC
PLEASE HELP ME!!!!!!!!!
Test your power supply for correct voltages. If they are all OK, then your motherboard is toast.
May 13, 2017 | E-Machines eMachines Refurbished EMA...
Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
May 17, 2008 | E-Machines eMachines Desktop PC
Emachine 5210 not working
how old is your emachine?? is your display in condition?? if so, your smps might've worn out.. this is what happens when the display is proper but u still don see anything on the screen..
Mar 12, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
