Question about HP DeskJet F380 All-In-One Printer
The printer wont print - control panel says it is poff line, yet it is all plugged in and installed properly
    President:
  • 627 Answers
Start - settings - printers and faxes
right click on your printer and click use printer online
Posted on Jul 14, 2009
Will print test page when I turn on printer, is communicating with computer but instead of words printing all I am getting are thicks black lines and dotted lines
If you are using a Windows PC you have to go to control panel, printer options, and calibrate the printer. Follow the steps to do so. Make sure you have the proper driver installed as well.
Oct 18, 2012 | HP LaserJet 1022 Printer
Does not print from my computer
Try to do a test print using the printer utility installed on your computer and also check if the driver is properly installed on your computer and if not make sure that your printer is using the printer driver from your setup CD.
Hope that helps...........
Jul 17, 2008 | Lexmark Z640 InkJet Printer
Wont Print no icon on the control panel or device and printer page down load to print test page Les
Browse below link, select OS, download full feature drivers.. save it..Installation procedure: Un plug USB cable, un install loaded drivers through control panel. Restart the system run the drivers, connect the USB cable when its appears on screen run rest of the drivers.. once installed check for icon in printer drivers.. print test page & confirm for the print as well as check for the scan...Link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3418707&lc=en&cc=us&dlc=en&lang=en&cc=us
Dec 30, 2011 | HP Photosmart C4580 All-in-One InkJet...
Printer does not print -- it's sounds like it is about to print and then stops
unplug it and plug it again.
make sure there's no jammed paper. make sure there aren't any other error messages. check to see if the paper is installed properly, etc.
make sure it is properly installed. check out if the printer options in control panel are set right. etc.
you should be able to troubleshoot and find the problem.
May 21, 2011 | Samsung ML 1610 Laser Printer
I need to get instructions on how to properly line up the print heads after installing a new cartridge on my printer, a Lexmark Z11 color printer. Thanks.
In XP - Maybe in Vista and 7 too.
Start
Control Panel
Printer and Fax
Highlight your printer (Z11)
RIGHT click it
Select Properties
Print test page
Follow directions
Dec 22, 2009 | Lexmark JetPrinter Z11 InkJet Color...
My HPD5160 wont allow me to delete a printing job. I have tried to turn it off but nothing is happening As this wont delete I cant print anything Please help Janice
In your printer folder you should select " Printer - Purge all print jobs" and then turn the printer off and on. The stuck job should disappear.
If everything else fails, as a last resort you can remove the printer from system.
Unplug your printer, go to Control Panel - Printers, select the one and hit "Del" on your keyboard, or right-click it and choose "Remove". If the system asks if you want to remove the driver (files used by this printer) choose No.
When the printer is removed successfully. plug it back in. It should be recognized and re-installed automatically.
Nov 22, 2009 | HP Office Equipment & Supplies
Printer installed & ready but wont print
found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Nov 22, 2008 | Lexmark X5250 All-In-One InkJet Printer
Wont print properly
63 NEEDS SERVICE ليزر جيت 4
Jul 17, 2008 | HP LaserJet 4si Printer
HP laser Jet 2420
cannot print to the printer server
Jul 04, 2008 | HP LaserJet 2420 Printer
No display and no light indicators when powered on
If the printer control panel is blank when you turn on the printer, check the following items.
1. Make sure that the printer is plugged into an active electrical outlet that delivers the correct
voltage.
2. Make sure that the on/off switch is in the on position.
3. Make sure that the fan runs briefly, which indicates that the power supply is operational.
4. Make sure that the control panel display wire-harness is connected.
The control-panel wire-harness connector can easily be disconnected when you install the top
cover. If the control panel does not work after the top cover is installed, verify that the wire-harness
connector is fully seated into its DC controller PCA connector.
5. Make sure that the firmware DIMM and the formatter are seated and operating properly.
6. Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again.
If the printer control-panel display is blank, but the main cooling fan runs briefly after the printer
power is turned on, try printing an engine test page to determine whether the problem is with the
control-panel display, formatter, or other printer components.
Engine test page
To verify that the printer engine (all printer components except the formatter, formatter DIMMs,
EIO products, and the stacker or stapler/stacker) is functioning, print an engine test page. Use a
small, non-metallic, pointed object to depress the test-page switch, which is located on the right
side of the printer
The test page should have a series of vertical lines. The test page will print from the last tray you
printed from. However, if the printer has been turned off and then back on since the most recent
print job, the page will print from tray 2. The printer will continuously print test pages as long as
the test-page switch is depressed. The printer will not print a test page if it is in PowerSave
mode.
A damaged formatter might interfere with the engine test. If the engine test page does not print,
try removing the formatter and performing the engine test again. If the engine test is then
successful, the problem is almost certainly with the control panel, or the cable that
connects it.
Hope this helps
May 24, 2008 | HP LaserJet 4250n Printer
HP DeskJet F380 All-In-One Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
