Question about Acer Aspire E380 ASE380-UD500A PC Desktop
Windows Media Player
I've tried burning a cd using Windows Media Player 10. I can't get it to work at all. I know that when I first got my computer I got a pop up from Acer pointing me towards a patch (or something similar), but I closed it thinking I would go back and do it later. Now I can't find where this patch is. I have searched the Acer site to no avail. I've searched the internet to no avail. Has anyone had a problem similar to this? Also, I've used the NTI program that comes with the computer and IT SUCKS. When I burn a cd it never works properly. I've tried playing it in many different cd players and it just will not work. It will say TRACK 1. Then nothing. Any help is much appreciated!
  • 57 Answers
Re: Windows Media Player
Try other software like NERO. There's more software you can use..
When burning a CD set your speed at 48kbps or 36kbps it is lower burning but its more efficient. If you burn on a maximum speed there's a risk that you get a poor quality of your burn.
Rate if this fix your problem.. Thnx!
Posted on Nov 17, 2007
0 characters
3 Points
I try to burn a playlist to a cd using Windows Media Player. Message says "no disc in drive" even when there is a disc in drive.
If your computer cannot burn CD's (try to burn any file to it) then it's probably gone bad and will have to be replaced.
If Media Player is the only app that will not burn the files, perhaps you need to download the latest version of Media Player. Or, perhaps, uninstall it and reinstall it.
Aug 19, 2011 | HP Compaq Presario SR1020T (PU167AV) PC...
How to Erase a Burned CD
CD-RW stands for CD re-writeable. This type of disc can be written on or "burned" multiple times. However, in order to burn music or data onto a CD-RW that already has something on it, you must first erase the current contents of the disc. No special software is needed to do this, as you can do it with the Windows Media Player program, which already comes installed on all computers with the Windows operating system. Regular CD-R discs cannot be erased or reused--the discs must be labeled as CD-RW.
Step 1.
Click on the "Start" menu button in the lower left-hand corner of the screen. Select "Windows Media Player" from the pop-up menu.
Step 2.
Select the "Library" tab in the main Windows Media Player screen.
Step 3.
Insert the CD-RW that you want to erase in the CD-ROM drive. Close the "AutoPlay" window if it appears.
Step 4.
Right-click the CD-ROM drive in the "Navigation" pane on the left side of Windows Media Player. Select "Erase disc" from the drop-down menu. This will automatically erase the contents of the disc.
on Jul 17, 2010 | PC Desktops
I am having a problem with my hp cd/dvd burner drive. when I go into wmp and try to burn something it tells me to connect a burner and restart the player, please help
What version of Windows Media Player are you currently using? If it is not up-to-date, try updating Windows and Windows Media Player. Then attempt to create the CD.
If that doesn't work, try updating the driver for your CD-ROM drive. Navigate to HP's Support Site, type in your machine model and search fot the CD drivers there. Update the necessary drivers and attempt to create the CD once more.
I hope I was able to help. Good luck!
Aug 08, 2009 | HP Pavilion Media Center m9340f Desktop PC
My Compaq Presario desktop will not burn CDs
Perform a system restore and take the computer back to a time before the problems started with burning, or you can download a different media player and try burning with that, real player as a good bit of software to use for burning and Nero is too (Nero is a devoted burning suite)
Get real player here >>>>>>
Get Nero 9 here >>>>>>
Good luck
Jul 08, 2009 | HP Compaq Presario S4000V (P8655P#ABA) PC...
Can not burn cd
Windows Media Player supports burning a music CD from your playlist. Help on using the software is available from the Help menu on the toolbar at the top of the window. The Acer may also have been supplied with another burning program such as Nero or Roxio. Again, these programs have help available. You can also find additional help online by searching for a specific problem.
Personally, I use and recommend InfraRecorder (available at It's a free open-source burning program that's pretty easy to use.
Now, if you're still having problems, please post a follow-up comment with the details (what you're trying to do, the software you're using, errors that are popping up, etc.) and those of us here should be able to get you going.
May 10, 2009 | PC Desktops
I have just brought a new pack of blank CD's, i am
Its a common problem with CDs. Check that your CD drive can PLAY CDs. If so either the CD drives optical head is dirty or your CD pack are low quality. CDs damage real easy. Try putting another CD, another brand or you must use CD doctor-something like that. Did that help
Mar 10, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
MY PC no longer "burns" cds-but there is no "error" message
My only suggestion is to borrow another burner if possible and see if you get the same error with with that one. This will be the simplest way to determine if you have a software problem or if your burner has a fault.
Dec 05, 2008 | Matrix 226R (VPR226R) PC Desktop
Cd burning on windows media player
you will need a burning software like Nero to burn cds
Nov 07, 2008 | PC Desktops
How can i change the format that my "magix Photostory CD & DVD" program burns my pictures/music to a DVD that WILL play on a home DVD player and not just a computer? I have a Windows XP
There are three ways to create a Video CD (VCD) that contains your photo stories:
You can obtain Microsoft Plus! Digital Media Edition and view the Photo Story 3-authored WMV file in Photo Story 2 by going to Play your story or create a video CD of your story and then create a VCD.using the Photo Story 2 Video CD-burning feature.
• You can obtain Microsoft Digital Image Suite 10 or above and view the Photo Story 3-authored WMV file in the Photo Story that comes with the Digital Image Library and save and burn to VCD.
• You can obtain VCD-authoring products that work with Photo Story files, such as MyDVD by Sonic Solutions or InstantCD\DVD by Pinnacle Systems. You can use these software to convert the Windows Media video (WMV) files into files that can be copied to a DVD and played in a DVD player.
Note: VCD and DVD-authoring software is not included with Photo Story 3.
Oct 14, 2008 | PC Desktops
I can't burn audio cd's from my windows media player?
please visit the above site for downloads.downloading the application may help you.instalation error may have occured .
Oct 03, 2008 | PC Desktops
Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
50 people viewed this question
Top Acer PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you an Acer PC Desktop Expert? Answer questions, earn points and help others
