Question about Yamaha RX-V661 Receiver
I have a yamaha receiver that turns off immediately after it is turned on. It makes a clicking noise then turns off and lately it clicks and doesn't turn on.
  • azam187 Aug 14, 2009
    Actually once it is off, I cannot turn on again using the remote control, the only way to turn it on is to unplug the electric wire wait for about an hour then plug it back on again and turn the receiver on. So, I already had figured this out but again it will work for about 10 to 15 min then it will turn off by itself. I read the solution and I checked all the connected speakers all of them seems to be connected correctly, I even unplugged all the speakers wires and plugged them back again, but the same thing happed, the receiver worked for a short period of time. However, the only speakers that I could not check are the once mounted on the ceiling and the once outside in the backyard, those I have no access to them.
  • azam187 Aug 16, 2009
    Yes, the solution was very helpful, I never gave a negative feed back, I just wanted to know more because I already did the first part of your solution before I sent my problem. Thank you for the second comment too :)
  • Yamaha Master
  • 19,396 Answers
Your unit is on protect mode. This happens because an internal fault had been detected, and the protection circuit keeps turning off the unit to prevent further damage, hence the clicking noise. The clicking noise is the protection switch that keeps turning off the receiver.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and receiver does not start, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on Jul 14, 2009
  • Ginko
    Ginko Aug 15, 2009
    To check the speaker you just disconnect them two by two and see if the unit stays on. You do not need to go to the roof.
    If it stays on 10 15 mins and speakers wires are fine, then there may be a blown capacitor on psu, or a transistor/power amp IC on amp final is bad.
    In that case the repair is done looking for bulged or leaky capacitors on power board or by testing the components on amp final section.
    Ensured that you tested the unit with a minimal set of good speakers and that the AC socket you are using is well grounded.
    Sorry that you gave negative feedback.
    Goodbye
    G.
  • 6,784 Answers
HI. this clicking sound is coming from the actual power sector(board). there is a relay on this board(power relay/circuit protector). it will not allow the unit to fully operate when there is a malfunction detected. This is a basic circuit failure. The power sector may have several components that are down at this moment. the bad news is, almost all Yamaha repair procedures will need to be sent it to be initiated. A Yamaha service depot or local tech service department will be needed in this case. the power board, and its components, are not available for consumer purchase.
Contact Yamaha for a repair ticket if possible. the power board will need to be replaced asap.
((Most older models will have an in line fuse that will absorb most power surges that will take out power sectors of this nature. Unfortunately, your unit dose not have this fuse.))
Posted on Aug 14, 2009
95 buick regal two fans in front , one make clicking noise after vehicle turned off. Its continues to spin and makes a clicking noise after turning off engine
It is normal for the fan to stay on after the engine is off. The clicking is not. Once the negine is cooled down and the fan is not running. check the fan by spinning it and try to locate the clicking noise. Make sure the fan doesn't wobble. If it does then the bearings are going out, replace the fan. The clicking could be something lodged in the shroud, clicking against the fan blade. Like a stick.
Jul 01, 2011 | Buick Regal Cars & Trucks
I have a yamaha htr-6130 receiver that won't power on. When I push the power button it makes a click noise like it used to when it turned on immediately followed by another click. No lights come or or...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 29, 2011 | Yamaha HTR-6130 Receiver
My yamaha rx-v596 makes a clicking sound but does not turn on
If it clicks twice almost instantly (on then off within 1/2second) then its got a serious power supply imbalance.
If it clicks on then 5secs later clicks off then one of the amplifier channels has probably failed and the protection circuit is tripping it off to protect itself.
either way its a repair shop job I'm afraid
Jul 16, 2010 | Yamaha RX-V596 Receiver
Yamaha receiver will not turn on. just a clicking
Your unit have had detected a fault and enter the protect mode. To determined, what exactly wrong with it, you will have to take it to Yamaha authorized repair facility.
Dec 26, 2009 | Yamaha HTR-5560 Receiver
Yamaha r-v98 turns on and immediately goes off. I haven't changed anything lately. It was playing then went off. Now it will not turn on for more than a few seconds.
Disconnect all speakers at the receiver then turn it back on, if it stays on, post a comment and I can help you troubleshoot further. If it still shuts off, it sufferred a power spike and needs to be serviced. They will replace 5-6 caps and 2 or three other parts, roughly 250 or so. Hope this helps
Aug 21, 2009 | Yamaha RX-395 Receiver
I have a yamaha receiver that turns off immediately after it is turned on. It makes a clicking noise then turns off.
check for low regulated voltages right before it turns off . Then replace the regulator with the weak, low voltage output. It could have something else wrong with it but you can start there.
Jul 13, 2009 | Yamaha RX-V661 Receiver
Yamaha R-700 Natural Sound Stereo Receiver won't turn on.
My stereo receiver aiwa MX-NH2000 can not turn on. It has standby.
May 03, 2009 | Yamaha Audio Players & Recorders
Htr 5590
Mine played for about and hour then cut off. It would cut off randomly after this hour. I initially thought it was overheating but after seeing other people had it happen after immediate turn on it must not be the case. Intermittent problems like this are difficult to troubleshoot which is why I came to this site hoping someone had found a simple answer. I am a technician and will have to do it the hard way. When I find the answer I will report my findings to this site.
Apr 14, 2008 | Yamaha HTR-5590 Receiver
Yamaha RX-V661 Receiver Logo
200 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
