Question about Universal Remote Control URC-6131N Remote Control
I have a comgenius tv universal remote control, switche tv from Grundig to a Philips Pixel Plus. How can I make this remote control work with the new tv ? any keys I need to push to active a new code ?
SOURCE: universal remote
need a code for a philips remote to control a zenith tz
Posted on Dec 27, 2007
SOURCE: i need codes for philips universal remote control
call 1-919-573-7854. Know the TV model and they will give you the codes
Posted on Apr 30, 2008
aprmaejun
  • 97 Answers
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
  • 20 Answers
SOURCE: philips universal remote codes for symphonics tv
try to ask a copy from the store where you bought the unit. or search in the internet. send me the model and ill help you search in the internet.
Posted on Dec 10, 2008
Can't my new controller to match to tv . I have a grundig elegance serial number 00357000743 . Thanks
The remote control contains the codes. If it is universal, you can search for an applicable one. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Mar 03, 2017 | Grundig Televison & Video
I'M LOOKING FOR THE 4 DIGIT CODES FOR A PIXEL TV TO SET UP A UNIVERSAL REMOTE CONTROL
How can I manually setup my universal remote control?
www.p4c.philips.com/cgi-bin/cpindex.pl?...
Philips LCD TV 32PFL7684H 81 cm (32") Full HD 1080p digital TV with Pixel Precise HD. 32PFL7684H/12. 32PFL7684H/12. Search for information about this product. Product ... Enter the 4-digit RC code of the device you wish to setup.
26PF7521D/10 26" LCD digital widescreen flat TV Pixel ...
Search for information about this product ... In digital mode, press the 'DIGITAL TV/MENU' button on the remote control to display the setup menu. Press the cursor up/down button to ACCESS RESTRICTIONS and press the cursor ... Note: If you have forgotten your personal 4-digit pin code, enter the universal code (0711).
Searching for Your Code - Universal Electronics Remote ...
www.urcsupport.com/html.php?page_id=314
Dec 22, 2015 | Universal Remote Control Televison & Video
Tune universal remote control
If you wish to get more details, check this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. More than Ten Lakh viewers cannot be wrong. Try this link too. http://electronicshelponline.blogspot.com/
May 19, 2013 | Grundig 7 In 1 Universal Remote Control -...
I need code for universal remote rca rcu403a for philips tv
The codes for the tv are
Philips ................................. 003, 006, 008, 013, 015, 026, 046, 051,
..................................................................... 055, 064, 077, 089, 094
Philips Magnavox ....................................................................... 026
You can get a free downlod of the manual on the link below.
http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCU403-Manual-Codes-Operating-Manual.html
Good Luck
Jan 08, 2011 | RCA RCU403 Remote Control
Codes for philips sru 3030 II universal remote
Mam dialkovac Philips Universal SRU 3030 no nemam kody pretoze som ich stratil pri stahovani.. hlavne potrebujem kody na TV GRUNDIG.. dakujem
Apr 06, 2010 | Philips Universal PH301S Remote Control
I have Grundig - ARGANTO MW 70-510/8DPL Television. I dont have codes for Grundig TV! My remote control: One For All URC 9960 B01 (Kameleon 8 Remote Control)
The philips universal code is 0218 for the Grundig Arganto 70
However, this misses two important buttons, the codes for these are below:
134, 142 EPG
212, 220 info
some others incase your universal remote doesn't have them...
006, 012 OK
020, 028 channel down
030, 038 channel up
004, 012 mute
133 aux
230 av
165, 173, 228, 236 1
239 2
237,238 3
102 4
100 5
103 6
039, 046 8
036,044 9
007,015 off
205 contrast -
206 contrast +
215, 223 sound menu
198 colour +
061 dig/ana
063 contrast
068 vol -
069 cont -
070 vol +
071 bri +
076 vol -
077 cont -
078 vol +
079 brig +
Nov 02, 2009 | One For All Kameleon 8 (URC-9960) EL...
Need a code for grundig tv
Grundig is an European brand, and these mostly use the remote control standard established by Philips. If you have some Philips TV models on your universal remote list, try these, one of them might do the job perfectly well.
Oct 28, 2009 | Televison & Video
Need code for black diamond remote for grundig tv
need a code for a one 4 all remote t tune it to a black diamond tv
May 19, 2009 | Universal Remote Control Televison & Video
Tv on standby
Hi Kjunse,
The Television may be faulty, but without reading the manual I can't say for sure. If you want to risk spend some money to find out, here is a link to a website selling the remote control you require for the GF70-600 TV. I've not had any dealings with the company but you could always contact them to check your buying an original (OEM*) Grundig remote before you buy one.
*OEM means, Original Equipment Manufacturer.
Hope this is helpful.
Regards,
Spare head 2.
Jan 04, 2008 | Grundig GF70-600 TV
Universal Remote Control URC-6131N Remote Control Logo
1,972 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
