Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Pull rope does not return - Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
    President:
  • 1,124 Answers
The pull cord return probaly broke..
You can find parts here
---> http://promotions.partstore.com/Brand-Landing-Pages/Poulan/Poulan-E.html?s=google
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
How do i repair pull string on my yard machine 135202 tiller
remove starter
get new rope
wind spring DONT LET GO UNTIL DONE
feed in new rope , tie knot in rope, replace handle ,tie knot in that end. NOW YOU CAN LET ROPE RETURN IN SLOWLY
May 10, 2014 | Mtd Products Yard Machines 158CC Tiller
Pull rope broke. attached back but cant figure out how to make the rope recall work
The recoil spring has to be pre-loaded about 5 turns, even when the rope is fully returned. When you pull out the rope, you increase this tension, but if you are starting from zero, there won't be enough spring tension to fully recoil the rope. Wind the rope on the spool, then rotate the spool about 5 turns in the direction that would "push" the rope out through the hole. Now put the rope through the hole and put the handle on it. If you got the tension right, it should be sufficient to easily hold the handle up against the hole.
Nov 18, 2010 | Honda Garden
I need help changing pull rope. How does return spring work?
once you have the recoil er out take your hand and spin coiler against the springs tension hold it in place and tie new rope on when you let go of coiler should pull new rope in housing
Oct 25, 2010 | Garden
How to replace pull cord on ryobi 725r trimmer?
Before you start... transfer the handle assy to the new rope. Remove the old rope and install the new rope just like the old one. Make sure to tie 1 knot in the end of the rope so that the rope ded not pull out of the handle
-Remove the recoil assy.
-Remove the old rope.
-Wind the spool counter clockwise until it stops
-Back up the spool until the rope hole aligns with the rope guide. DO NOT let the spool unwind. It really takes 2 people to do this.
-Burn the end of the new rope with a match and very quickly while it is still soft. pinch the end of the rope to make it as small as possible.
-Thread the new rope through the rope guide and into the hole for the knot of the spool.
-Use a scribe or needle to lift and pull the new rope through the hole
-Tie 1 knot in the rope
-Pull the knot into the hole in the spool
-Let go of the spool and the rope will rewind
-Install recoil assy
-RETURN TO SERVICE
Thanks for using FixYa!
Kelly
May 09, 2010 | Garden
The rope on my generator gets stuck as i pull to turn it on
Assuming the rope stays on the internal pulley, it is NORMAL for the rope to require great force at points in the cranking cycle (once per revolution of the crankshaft). These are the compression strokes and the force is MANY times the initial pulling force. If the rope returns easily, then the starter assembly is probably normal. It takes a strong arm and fast movement to start the enginess via pull rope. Some units have a compression release to ease this a bit.
Mar 22, 2010 | Electrical Supplies
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Sep 03, 2009 | Garden
Replacing the pull rope
The solution to this one is very tricky. You have to remove the shroud to access the inside of the spring return. Pull the rope out but make sure it is still attached to the spindle check to see if the return spring has broken. If it is then it will have to be replaced.
Jul 27, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Recoil not returning rope when pulled
There is a spring inside the pull cord housing that makes the cord come back in, it probably undid itself, remove the housing cover and rope assembly and you will see the spring, you need to retighten it and place everything back. hope this helps
May 31, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
May 06, 2009 | Boating
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
225 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
