Question about Samsung RS2556 Side by Side Refrigerator
Samsung RS55XDGNS side by side Refrigerator does not cool anymore
Deep-Freezer/Ice-maker work fine
Frigo will not cool anymore and goes to 20C (68F) instead of 1-7 F (35-45F)
Where should I start looking or how to analyze this problem??
Please help
  • felixvanwest Jul 14, 2009
    Hello Nicolocarlo,
    1. no build up of ice around the coil, I cleaned a little bit the dust with the vacuum cleaner.
    2. fan runs properly and quite often, but not permanently; it sometimes shuts off. Not sure why/when!
    3.condensor/motor is warm and zooming and does not show any leaks in that area at all.
    4.the frig has been very noisy for the last 2 years, but not anymore now? That noise was mainly coming from the back of the refrigerator side around mid height behind the illuminated panel at the inside.
    Remarks:
    temperature down under in the frig. is coldest (probably because it comes from the freezer which works fine ). But in the top I mesure 20+ C with a seperate temp. meter.
    Also from time to time (not often enough!) the temperature on the display goes fairly quickly down from 20 to 7Ce, but unfortunately only for a short period of a few minutes. I have no idea why?
    Please help again,
    Felix
  • felixvanwest Jul 15, 2009
    Where can I locate in the Samsung American machine the blower which blows the cold air from the freezer to the refrigerator????
    President:
  • 1,136 Answers
Hi, Sounds like you have most everything. Have you removed the rear panel inside the freezer section? Removing this panel will let you see if there is frost building up on the evaporator coil which will stop air flow to the fresh food side. If the coil is plugged up with frost, we need to narrow down the defrost issue. If the coil has some frost but not totaly getting frost on every coil (a thin layer of frost), then it is possible the compressor is getting weak and not pumpping the coolent like it should. The evaporator fan motor you had mentioned is also behind the rear panel.
Please let me know if this helps you aor if I can assist you further.
Thanks,
Vic
Posted on Jul 15, 2009
  • Victor
    Victor Jul 17, 2009
    Hi, Is there anything more I can help you with on this matter?
    Please letme know.
    Thanks
    Vic
    Top Expert:
  • Samsung Master
  • 76,164 Answers
Is the blower fan working that sends cold air from freezer to fridge?
Posted on Jul 14, 2009
    President:
  • 2,187 Answers
The cold air which cools down the entire fridge comes from the freezer. Check first the coil at the freezer at its back if there is build up of ice. If there is, have the freezer unplugged and have the ice melt. Clean the fridge while doing the process. Most likely that the thermistor may have been frozen. If so it may think that the rest of the fridge is at the target temperature. The ice maker will not be affected since it the ice temperature is directly connected from the freezer. If your model has a fan, check if it is working and properly circulating air. If it does not, it could be a loose wire or the fan may be faulty. If all checks OK you may want to check the condenser at the back checked for leaks and have the freon pressure checked.
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
Hi. We moved to a house with an integrated Teka A-FC1359 Fridge/Freezer. It was working fine. We switched it off 3 months ago. Now we've swithched it back on but it's not working.
It can be issue with faulty compressor capacitor.From main power outlet the power goes to capacitor beside compressor and from there power goes to compressor motor,then after that all unit works.May be that capacitor got shorted or loose from its actual connection.Or other possibility is faulty power wire of refrigerator.Get the wire checked with continuity tester to confirm its not broken in between.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
My Samsung RS2556BB refrigerator ice maker is not making ice anymore. The freezer still very cold but there is no water coming into the ice tray. I switched the relay in the back and pressed the water...
These will help.
Thanks,.
Dec 22, 2012 | Samsung RS2556 Side by Side Refrigerator
Ice maker has stopped working and auto defrost does;nt seem to be 100%
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
kjffkjk
May 20, 2010 | Samsung RS2630SH Side by Side Refrigerator
Ice maker doesn't make ice anymore
Here is a solution I came up with. Pour water into the ice tray by hand and you have ice! Just a little humor for you all. I still haven't fixed mine.
May 27, 2008 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Samsung RS2556 Side by Side Refrigerator Logo
96 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
