Question about Dell 4100MP Multimedia Projector
Dell 4100mp shuts down
After 15-20 minutes the "Overheat" light comes on and the unit shuts down. It is mounted near the HVAC outlet and this has not helped. Could the cooling fan not be working?
    Problem Solver:
  • 8 Answers
It sounds like the fan in you 4100 is defective.
Posted on Oct 07, 2009
How do I remove the center console where the heater control switches are located on a 2006 Pt Cruiser GT
DESCRIPTION A manual temperature control (MTC) single zone type heating-A/C system or a manually controlled heater-only system is standard equipment on this model, depending on market.
To maintain the performance level of the heating, ventilation and air conditioning (HVAC) system, the engine cooling system must be properly maintained. The use of a bug screen is not recommended. Any obstructions in front of the radiator or A/C condenser will reduce the performance of the A/C and engine cooling systems.
The engine cooling system includes the radiator, thermostat, radiator hoses and the engine coolant pump. Refer to 7 - Cooling for more information before opening or attempting any service to the engine cooling system.
All vehicles are equipped with a common heater, ventilation and air conditioning (HVAC) housing (1). The heating-A/C system combines heating, ventilating and A/C (if equipped) capabilities in a single HVAC housing mounted within the passenger compartment beneath the instrument panel. The HVAC housing includes:
  1. Mode-air doors (2)
  2. A/C evaporator (A/C system only) (3)
  3. Recirculation-air door and actuator (A/C system only) (4)
  4. Blower motor (5)
  5. Mode control cable (6)
  6. Temperature control cable (7)
  7. Heater core (8)
  8. Blend-air door (9)
On heater-only systems, the A/C evaporator is omitted from the HVAC housing and is replaced with an air restrictor plate.
Based upon the system mode selected, conditioned air can exit the standard heater-only or optional heater-A/C housing through one or a combination of the three main housing outlets: defrost, panel or floor. The defrost and panel outlets are located on the top of the HVAC air distribution housing and the floor outlets are located on each side of the distribution housing. Once the conditioned air exits the HVAC housing, it is further directed through molded plastic ducts to the various outlets within the vehicle interior. These outlets and their locations are as follows:
  1. Defroster Outlet- A single large defroster outlet is located in the center of the instrument panel top cover, near the base of the windshield.
  2. Side Window Demister Outlets- There are two side window demister outlets, one is located at each outboard end of the instrument panel top cover, near the belt line at the A-pillars.
  3. Panel Outlets- There are four panel outlets in the instrument panel, one located near each outboard end of the instrument panel facing the rear of the vehicle and two located near the top of the instrument panel center bezel.
  4. Front Floor Outlets- There are two front floor outlets, one located on each side of the center tunnel near the dash panel.
  5. Rear Floor Outlets- There are two rear floor outlets, one located on each side of the floor panel center tunnel near the front of each rear seat foot well.
  6. REMOVAL
    WARNING: Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury.
    NOTE: Illustration shown with instrument panel removed for clarity. (Refer to 23 - Body/Instrument Panel/BEZEL, Instrument Panel - Removal).(Refer to 24 - Heating and Air Conditioning/Controls/CONTROL, A/C and Heater - Removal).(Refer to 23 - Body/Instrument Panel/COVER, Steering Column Opening - Removal). 5. Remove the screw (1) that secures the temperature control cable (2) to the left side of the HVAC air distribution housing (3). 6. Disconnect the temperature control cable from the blend door pivot lever (4) and remove the cable from the vehicle.
    REMOVAL
    WARNING: Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury. (Refer to 24 - Heating and Air Conditioning/Controls/CONTROL, A/C and Heater - Removal).(Refer to 08 - Electrical/Clock - Removal).(Refer to 08 - Electrical/Power Windows/SWITCH, Power Window - Removal).(Refer to 24 - Heating and Air Conditioning/Distribution/OUTLET, Air - Removal).
Oct 31, 2016 | Cars & Trucks
Dell 4100mp fan won't turn off
I reckon ya got a busted thermostat and that'll probably cost more to fix than the unit is worth so you may have to just unplug it from the socket when yer finished using it. Thats my only suggestion, sorry l could'nt be more help..
Dec 04, 2017 | Dell 4100MP Multimedia Projector
The 4100mp dell projector will kick off about 5 minutes after bing turned on. I read somthing about a filter possiblly being cleaned.
hi,
Try to reset the lamp hour of your projector. For that do the following.
1. power on the projector.
2. Press the menu button
3. select lamp settings
4. Select lamp reset
5. Select yes to reset the lamp hour.
OK
Jul 29, 2011 | Dell 4100MP Multimedia Projector
It is a Bryant Legacy AC unit. Model #123RNA060-B. It has been running fine, now it has suddenly shut down. The interior fan is working, but the fan at the compressor shuts down. It will work fine for...
I had a unit do the same thing to me, everytime I would leave, it would stop working again. I had a bad fan motor that would spin fine and work for a little while, but would shut down. It was the motor windings that would overheat and shut off, as soon as they cooled, it would start back up. One way to check is to feel the top of the unit where the base of the fan mounts and see how hot it is, best to check while it's not working how it should, but try not to run it very long or you could damage the compressor. Hope this helps!
Jun 27, 2011 | Bryant Heating & Cooling
Dell 4100mp will not power on
are the lamp and filter covers on correctly. Is the power cable plugged in properly. Is the power switched on. Do any lights come on at all. Some more clues would be helpful
Jun 27, 2011 | Dell 4100MP Multimedia Projector
Thermostat display has an image of a flame
Sounds like the circulating fan on your furnace is not running. This will cause the furnace to shut down due to overheating, and you can smell the overheating as well. You will probably have to press a reset button on the burner to clear the overheat shutdown. Check the fan belt if there is one. If no belt you have an integral motor. Remove all power from the system and make sure the fan spins freely. If it doesn't, try to work some oil into the bearings. These things always fail on a holiday, but if you can't get the fan spinning you're going to have to call in a HVAC specialist.
Jan 01, 2009 | Honeywell Programmable Thermostat Heater
Dell 4100mp projector
colorwheel. you'll have to send it in for repair. dell does not readily sell parts.
Sep 01, 2008 | Office Equipment & Supplies
Dell 4100MP Multimedia Projector Logo
361 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
