Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Stanley 17.5 hp 42"cut riding mower, purchased in 2002. Lately it has started to move slower, especially on grades, and really slow in reverse. It has a hydrostatic transmission. Are there adjustments that can be made to help this. The engine is as good as ever. Thanks
    President:
  • 1,124 Answers
Sounds like its slipping..
Have you checked the hydro fluid ?
Are there any leaks ?
Could be an adjustment in the pedal..
Look at all the pedal linkage and you might find some adjustment there..
Or - maybe a moving part is waring out in the linkage..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
  • Steve Henderson
    Steve Henderson Sep 23, 2011
    I have a stanley 22hp 52" cut with hydrostatic trans with same problem the manual tells you nothing about checking fluid or changing fluid that is what I want to know too!!! Thanks!!!
  • Steve Henderson
    I think my trans is sealed and thereis no way The manual tells you how to work on it!!! Any info would help,mines making noise and gets slower the hotter it gets!!! Thanks
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Weed Eater One WE 261 moves very very slow in reverse
Check drive belt. May old and slipping.
Jun 29, 2014 | Garden
Drive belt getting hot and slowing down
check bearings of all spindles the belt drives Find the one that has seized and replace the bearings. They all suffer from water and dirt getting in
May 30, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Jun 16, 2012 | Garden
Craftsman Riding Mower (24 HP 42 in cut Model 289254) with throttle issue. Very slow in 6th gear
follow the throttle cable all the way down to the engine. Have some one move the throttle up and down to see if the throttle plate is opening and closing all the way. You can loosen the screw holding the throttle cable and move it back and forth to see if it will allow the throttle plate to open and close correctly. It may have slipped when the assembler tried to tighten it.
Mar 10, 2012 | Craftsman Garden
I purchased a used Craftsman LT 1000 17 hp 42"
I've had to do this at least 5 times. If you look under the body, there are two supports that carry the mower deck and lift and lower it. Each of these has a nut that holds up the deck and the nut is on a stud that goes up and down when you raise or lower the lever. Put the deck in the middle of it's range, around #3, make sure the key is off, move your blades so they are on the right and left edge of the deck.
Get yourself a device to measure blade to ground height, I have a block of wood that is 3 inches long. Make sure your floor or ground is level and tires are properly pumped up. Then raise or lower the adjustment nuts until both sides are equal height.
Gary
Jun 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 42 in poulan pro riding mower that keeps cutting off while mowing the lawn
safety switch on seat, are you bopping or are you going to fast for the mower slow down speed kills ha ha , other than that get it serviced maybe, try going slower they are not v8 mowers , hope this helps ,, keeps cutting off means it does start again yes
Jun 05, 2010 | Garden
We need the electrical diagram for a 17 HP Craftsman 42" cut riding mower. Model-311707 Type-0321-E1
this is as close as i can find.. take a look and see if you can use this diagram...good luck. go to page numbers 34 and 35
http://www.hammerwall.com/Download_Manual/18200/
Apr 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,000 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
