Question about Samsung TXN3271HF 32" TV
I have a RCA tv wont turn on and makes a high squealing noise
    Problem Solver:
  • 15 Answers
Your TV is actually functioning but their is probably a leakage on high voltage supply.
Warning : The next procedure should be done by an expert.
1.Clean the anode cap mounted on the CRT.But before touching the cap be sure that the voltage stored in the CRT is discharge to avoid risk of electric shock.It is done by creating a path of conduction from anode cap to chassis ground.
2.After cleaning the anode cap and the CRT surface.Attached the anode cap to the CRT.Be sure after attaching the pins correctly push and vacuum the socket and the cap to seal leakage.
Posted on Jul 14, 2009
My tv wont turn on you push the button and it makes a lite squeal noise then the light will turn off and on 3 times the turns off
sqealing noise is a general syptom of a shorted horizontal output transistor and a bad flyback. it could be more but as a technician that the first thin i would check.
Oct 30, 2010 | RCA Televison & Video
My tv makes 3 even high pitched squeals when i turn it on. about 1 second each, then powers off. No picture no sound. All imputs. What do you have for suggestions on what it could be.
One of most two common reason why your set will not come on, is because it has lost the high voltage, the first thing to check is your horizontal output transistor, to see if it is shorted, it will be located bay the flyback, mounted on a metal heat sink. That is what is causing a squealing noise.
Oct 16, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Squealing noise
a shop will need to do the repairs on the tv..its not something a novice shouldd try to repair
Aug 29, 2008 | RCA P52926 52" Rear Projection Television
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
Samsung TXN3271HF 32" TV Logo
120 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
