Question about Tools & Hardware - Others
How to change blade on Ibea 350 electric lawnmower
    President:
  • 1,124 Answers
Should be a big nut on the uderside of the blade.. It might be stubourn.. Hold the blade with a rag (so you dont hurt your hand) and that should give you enough levrage to undo the bolt..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
I have a ibea vision 2003 lawnmower but I have no manual where do I get one from ??
https://www.manualslib.com/products/Ibea-Vision-Ib-Vac15c4h-4193062.html
Dec 29, 2017 | Garden
How to change the blade on my einhell lawnmower
turn it over and look at the blades . that might help you figure it out .
Jul 14, 2016 | Worx 17In Electric Lawnmower By
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
How to fix a wobbly ceilng fan
wobbly cieling fan
1. make sure all mounting screws between the fan and the ceiling are tight. There is probably an electrical box mounted in the cieling that the fan is screwed into. I would turn the fan light on and then keep flipping breakers off, on at a time ,to see which breaker turns off the fan light. leave the fan light breaker off and you can unmount the fan from the cieling electrical box. The electrical box may have several holes in it for mounting screws and prehaps there are some holes left empty in the box that you can put more wood screws into to help keep the electrical box more firmly mounted and that may help lessen the wobble.
Its ok to bend the electrical wiring aside to put more screws in. Just be reasonably gentle with the wiring and then bend it back somewhat to where it was before you started. make sure that wiring does not get pinched between the fan and the electrical box and that all wiring resides inside the box.
#2 This is harder to do. you need to balance the blades for the fan ,similar to how a lawnmower blade is balanced after sharpening and before remounting the lawnmower blade on the mower. also kinda like balancing a car tire. I have a lawnmower blade balancing fixture that i bought at the lawnmower shop, but i dont know if there is a fan blade balancing fixture that you could buy from somewheres. Maybe try google.com,bing.com or ask.com and type into the search box fan blade balancer
or fan blade balancing fixture or fan blade balancing jig.
PLEASE read the directions or SPECIFICATIONS before you buy the fan blade balancer, only to find out that it only fits 9 inch diameter fan blades, and your blade is 2 4or 36 inches long.
The balancer may have to fit a certain diameter hole at the center
of the fan blade. When you finally find out which side of the fan blade is heavy, you have to grind , with an electric grinding wheel, some material off the heavy side of the blade so that it is the same wieght as the light side of the blade.
Try to imagine a cone shaped center[like step drills] like the capital letter V ,only up side down, so that the point is up. ON the underside of the inverted V is a needle tiped post that upside down V can pivot in any direction on. The hole in the middle of a lawnmower blade is centered somewheres on the outside of the inverted V, depending on the diameter of the hole in the lawnmower blade. The heavy side of the mower blade will go down and may touch the level asphault or the table top, depending on where you placed the balancing fixture. THen i would grind off metal until the heavy side can up to be level with the light side of the mower blade and it was considered balanced.
an appliance repair parts store may sell fan balancers, but if the would fit your cieling fan, better ask before you waiste your money on something that wont work for what you want.
Try calling up customer service of the manufacturor of your ceiling fan and ask about repair service for your brand fan.
see what repair service has to say, im sure many others have asked them about wobbling fans.
so they should have all the answers down pat.
Two more thoughts.
1.
.MAKE SURE ALL SCREWS THAT HOLD FAN BLADES ON TO THE HUB ARE THERE AND are TIGHT. one loose fan blade mounting screw or one missing fan blade screw will unbalance the whole thing and cause wobble.
2. the fan motor shaft bearing could be worn out or round or even egg shaped. If this is the cause, the motor must be diaassembled and new fan shaft bearings installed or the fan motor must be replaced.
good luck and have fun!
Sep 22, 2013 | Hampton Bay 24002 Ceiling Fan
Can't loosen nut to change lawn mower blade
you are going to need a impact gun to get it off
Apr 28, 2013 | Garden
I have an older Black & Decker electric lawnmower
Does the mower sound like it is running at full speed? Have you double checked that the blade was not installed upside down?
Aug 06, 2011 | Black & Decker Garden
The blades on my Flymo 350 lawnmower have become blunt. How easy it is to replace them once i have purchased replacement blades?
It is a matter of unscrewing the bolt that holds the blade on just make sure when installing the new blade that it locks into the mounting shaft correctly on some mowers there is a mating hole to shaft pattern that allows the blade to interlock onto the shaft yours may just have a rectangular support the blade fits into just make sure when you tighten the blade it is set into the shaft correctly and you are wearing a pair of raw hide gloves when holding the blade as you tighten or somehow block the blade with a piece of two by four wood.
Sep 11, 2009 | Garden
I have a sunbeam power drive electric lawnmower wont cut the gras
The motor is failing. A common occurrence in this type of mower.
Jan 22, 2018 | Garden
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Electric lawnmower
Need to check blade and replace.Blade is out of balance causeing vibration. If you continue to use cener shaft bearing will also wear out and cause vibration. Buy new blade and if vibration is still there return blade.Mower is not worth bearing replacement. Buy new mower.
Please take time to rate .Thanks
Mar 28, 2009 | Electric Garden
Tools & Hardware - Others Logo
919 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
