My 19 inch flat screen KOGI monitor occasionally makes a high pitch sound with a ripple effect distorting the image on the screen. What is the problem?
  • 1,684 Answers
I have seen this type of problem on other brands of LCD monitors. The issue is either a bad solder joint on the high voltage backlight transformers or the transformer itself going out. The high pitched sound you are hearing is a high voltage spark. If you have a soldering iron and feel like opening your monitor then you may be able to repair it. Look for 2 identicle transformers these are the backlight ones. Resolder the connections on both units. While you have it open check for bad capacitors and replace any that may have been damaged by the transformers. You can see what the capacitors look like when they go bad at our web site: www.ccl-la.com/badcaps.htm
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Posted on Jul 14, 2009
Dear Sir the monitor view is like when we draw the circle it will display like oval size so what to do the problem
You need to set your PC video resolution to the native resolution of this monitor, which is: 1440x900 @60Hz.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Feb 22, 2011 | Acer AL1916W 19" LCD Monitor
Gateway 19 inch fpd1976w problem
Power supply will be the first place to look, look for bad caps (bulging tops or bottom seals). Check it out and post back what you find so we can guide you further, see example of failed monitors due tobad caps: http://s807.photobucket.com/home/budm/allalbums
The high pitch you are hearing can be from the bad lamp soldering connection, it is arcing.
Jan 24, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
What is the biggest wide screen monitor can I get to use with the Dimension 2400 and the integrated video?
The monitor (19-inch, non-flat screen, 0.24 dot pitch) presented a more than acceptable image, even at its maximum supported resolution (1600X1200 @ 75Hz). We settled on a more reasonable 1280x1024 @ 85Hz as our preferred setting. According to the documentation, the recommended resolution is 1280x1024 @ 75Hz .Many of the newer LARGE monitors are limited to 60Hz and/or a larger dot pitch...So..look for a low dot pitch(below 0.27) and the ability to run at 1280X1024@75Hz . Passed that, the size is up to you.
Nov 18, 2009 | Dell Dimension 2400 PC Desktop
Kogi L9CH monitor - black screen
return for a replacement, the screen is broken
Sep 13, 2009 | Kogi L9CH 19" Flat Panel LCD Monitor
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Kogi L9ch 19 in flat monitor
(I posted the latest post.) Change the resolution. (Mine was 1024 by 768, so I changed it first to 800 by 600 and then back to 1024 by 768, and it's back to normal!)
Hope that helps.
Feb 13, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
