Question about Linksys Computers & Internet
I just got a linksys wireless router and got Internet but my Dell inspiron 11 3000 won't connect to the Internet the wifi says limited with no internet why is that can someone help me out please
  • Linksys Master
  • 2,276 Answers
You can remove the preferred wireless networks from the list and try to reconnect.
make sure that you have the correct network key.
Check the link below for step by step solution.
Limited or no connectivity
Posted on Jan 04, 2017
  • 2,760 Answers
Sounds to me with that type of message that machine has connected to router. but router is not connected to modem/switch depending on what type of internet you have
if router has usb ports and you plug a thumb drive into it and pc can see that drive yes my thoughts are correct
Posted on Dec 01, 2015
SOURCE:
Wifi for b130
SETTING UP A BROADBAND CONNECTION
First you need to decide what type of broadband andInternet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network which uses the mobile/cell phone network and can beseparate or combine with your cell phone account
Note - Combined services generally offer discount pricing and may include amodem/wireless router.
If you use a wireless router with the DSL or Cable Internet service and yourlaptop has a wireless card then you can also connect to the Internet at WiFihot spots like McDonalds, Star Bucks, the Airport etc.
If you use the wireless 3G wireless broadband service, then you can access theInternet anywhere where your ISP has 3G wireless coverage. You need to checkthe service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to checkwith the various Internet Service providers to see if they can offer and thecost of the various plans.
Note the download limits and the associated additional costs if you exceed themonthly download limits. Once you sign up with a Internet Service provider,their documentation will include setting up instructions and/or installationCD.
Jun 02, 2012 | Dell Inspiron B130 Pentium M 1.7ghz...
Cant connect to my dell inspiron 8100
I think you should check the wireless settings of your router first.
If your wireless network is secured then make sure that you have the correct wireless network key WEP / WPA .
If your router is too old then it will be better to upgrade the firmware of your Linksys router.
Jan 01, 2012 | Linksys Wireless-G WRT54G Router
Just had a new wireless card fitted and I am trying to connect to my router
I recently purchased a new wireless card for my desktop, it was a Linksys 54g with speedbooster but after the switch the networks I was connecting to (Free wireless from my apartments) will no longer connect. The old card that I had was just an offbrand card which used the microsoft zero connection tool to configure, this new card attemps to use the software included and ive tried to switch between the two different connection configuration tools both can detect the routers but when trying to connect it does not even get to the aquiring access key stage. the router is not passworded so I guess I was just wondering can this new card not connect to the router maybe due to brands? possibly the router is belkin or something of that sort and this linksys card cannot connect? I had before gotten it to connect at the very good 54kbps or whatever the number is but it would not let me access internet and then said limited/no connectivity. I also tried to change the settings on my wireless card and set them to 802.11b only, 54g auto, 54g LRS or Performance but all had the same result, I switched the default channel to match that of the router as well still nothing.
dell inspiron 1525 battery
Oct 03, 2010 | Dell Inspiron 1525 Laptop
Suiddenly lost my wireless connection. (Dell Inspiration E1705)
make sure the wifi enabled and wifi light is on. to enable it press "Fn" and "F2"
Feb 19, 2010 | Dell Inspiron E1705 Notebook
Inspiron 6400 detects networks but does not connect to internet
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
Apr 11, 2009 | Dell Inspiron 6400 Notebook
Wrong ip address, need to reconfigure
Im assuming youre using an integrated ethernet card since you say "adapter port" and "unplugged". So....
Since you reformatted your HD with O/S re-installation you may also have to reinstall or update it to the correct ethernet adapter driver. As far as the ethernet card set-up - copy your ethernet card property configurations from the other computers. Also copy configuration settings from your Internet Explorer options.
Jan 11, 2009 | Linksys Wireless-G WRT54GS Router...
WIFI
You can go for a wireless router, so that you can access internet anywhere in your house, ,
Jul 18, 2008 | Dell Inspiron 5100 Laptop
Poor Wireless Reception on DELL Inspiron
It is likely your wireless card reception. try an external usb wifi adapter it shouldn't be expensive.
regards
Mar 01, 2008 | Linksys Wireless-G Broadband Router
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Computers & Internet Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
