Washing Machines Logo
Don Forrester Posted on Nov 30, 2015
Machine filling up with water but not starting hoover 750la
Fills with water, will empty, will not start to wash has a funny noise
Luis Coelho
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Dec 01, 2015
 Luis Coelho
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
10614
Points
64
Did you try with temperature setting to the minimum?
Normally the machine needs to heat the water at programmed temperature before starts, it fails to do it because some issue on the heating system it would not start....
Hi My Hoover dynamic next washer model no DXC A48AW3/1-80 has an issue the machine starts to fill then appears to over fill then stops and gives an error code E02, any thoughts please
Hoover suggests that the water fill valve(s) may be turned off. Error 2 means It cannot fill correctly according to their owners manual.
When I Fill my washing machine (Top loader Lg Wf-T7015tp), it Makes a Funny Noise and die when I start the program.Is it the Capasitor or is it the v-belt tension?
If the noise is only when this function of filling, and if you are only using one of the two fill valves, may be due to the magnets of the inlet valves of the water, which are activated in filling and are disabled when you start the program. that noise is normal unless it is very strong and is the preamble to the damage of the two valves.
Hoover 750la will spin but wont pump water out
lower the waste pipe into a bucket to drain as much water as you can out of the machine, gravity will pull the water out of the machine, continue until it is as empty as possible. Remove front filter which is on the bottom right hand side and check for obstructions.
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
28helpful
3answers
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Washer filled with water and then does nothing but make a clicking noise
If it's not spinning, the transmission is bad. If it's just not emptying the water, the pump is clogged or bad.
Unless you can replace the transmission yourself, it would be a better bargain to buy a new washer.
4helpful
2answers
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
