Question about Kenmore 24 in. 16462 / 16464 / 16469 Built-in Dishwasher
I have a kenmore dishwasher but no kickplate. How
I have a kenmore dishwasher but no kickplate. How do I find one?
  • 85 Answers
Hello cantrell_m,
Sears appliance parts can supply you with the part you need. You will need to provide the model #. Here is their phone # (800) 252-1698.
I hope this is helpful for you. Positive feedback for me is appreciated. Thank you! NormanZ
Posted on Jul 14, 2009
How do I install miele dishwasher toe kick?
Dishwasher Kickplate (part #00446633) - How To Replace ...
? 2:07
www.youtube.com/watch?v=8GJnHVlAx5Q
Mar 5, 2014 - Uploaded by AppliancePartsPros
Buy the new Dishwasher Kickplate 00446633 http://www.appliancepartspros.com/bosch-kickplate-446633 ...
Sep 26, 2015 | Miele Dishwashers
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
Remove kick plate
Tip the unit back and put your hand under each side in turn underneath, the kickplate is held on via clips near each front foot (the retainer lug is part of the kickplate) this will release it. To reinstall offer the kickplate up under the door panel and give the bottom a push to relocate the clips.
Mar 19, 2013 | Bosch SMS68M02AU Dishwasher
Clean light flashes continuously. None of the cycles work except drain.
Might help if you provide the model number of the dishwasher.
It is likely the float switch at base of dishwasher is cutting in. Have you tried to turn the power off and back on.
Need model no.
Jan 22, 2011 | Kenmore Dishwashers
How do you stabilize a kenmore dishwasher not to move
Greetings,
open the door and there should be two brackets that screw into the counter to hold the top. I would remove lower kickplate and you will find legs that you can move up or down,...I would set your d/w in place and scew the legs up to desired position...Then, screw brackets into top above d/w..this will hold d/w into place..if your happy with my answer. please let me know....thank you,
..........................Bruce Denton Master Appliance Technician
Dec 28, 2010 | Kenmore Dishwashers
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
How to disconnect
To disconnect ....remove the kickplate...after turning off the electric and water...remove the electric wire from the dishwasher by opening the e;electric box and undoing the wires...also remove the water pipe/hose from the inlet valve...then remove the drain hose from the drain and makes sure that it will not catch as you pull out the dishwasher...then remove the two screws that hold the dishwasher fast to the countertop and the pull the dishwasher straight out from under the countertop...
heatman101
Sep 15, 2010 | Kenmore Dishwashers
How do i power my new kenmore dishwasher?
You have to take the bottom kickplate off and the electrics box is on the right side. It has a cover on it held on by one 1/4 inch hex head screw. You have to attach the power wires to the dishwasher wires with wire nuts and the ground wire to the ground screw inside the electrical box. All this information is in your installation manual. Read it.
Jan 29, 2010 | Kenmore 17459 Free-standing Dishwasher
How do I change the front panel of my Kenmore protable dishwasher
Remove the strip at the bottom of the panel above the kickplate it should just pull right off and then you can get the panel out the strip is about a 1/2 inch wide that you need to remove and it just snaps in place in a little track I have a Kenmore 17829000 and thats how you do it on that one hope that helps
Jun 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 24 in. 16462 / 16464 / 16469 Built-in Dishwasher Logo
220 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
