Question about JVC AM FM CD DET FACE CAR STEREO
Trying to put in a ford f100 1981 - JVC AM FM CD DET FACE CAR STEREO
I tried to put gas in my 2015 ford fiesta and I can't get the nozzle to go in
Hi Jackie.
That usually happens when you're trying to put in the wrong kind of fuel.
Nov 08, 2015 | Ford Cars & Trucks
How too put my top down on my 1996 ford mustang
The car must be put in park or neutral and the emergency brake applied before you push the power button to lower it. It's a safety feature to prevent people from trying to open or close them while in motion.
Mar 24, 2015 | 1996 Ford Mustang
I have a 2002 Ford explore I'm trying to put gas
Couldnt tell you without a good look to be honest but i suspect a damaged breather pipe from the tank to the filler
Aug 26, 2013 | Cars & Trucks
No aux audio ford edge
The ford radio has two Aux out puts. one of them being a usb jack. if that is the input you are trying to use plug the device in and use the voice command and ask it to select usb.
Apr 06, 2013 | 2010 Ford Edge
Will my 351 modified fit in place of my 360 in ford f-150
Probably but find a ford car club and the members will be glad to help with the problems you will encounter.
Mar 13, 2013 | Cars & Trucks
I'm trying to put the tension pulley from a Ford
The 6 cylinder 1.8 engine in the Mazda is not the same as the 3.0 engine in the Taurus.
So I doubt the parts would interchange.
Feb 24, 2013 | Cars & Trucks
Can't break the spindle nut loose on 1983 Ford F-150 4X4 Trying to replace rotors
put some w-40 if that don't work put some heat on it do you have a breaker bar
Feb 05, 2011 | 1983 Ford F150
I trying to fix my 2001 ford taurus i had someone put a new gasket on it and i think they put the spark plug wires in the wrong spot so i need a firing order for a 2001 ford taurus v6
the coil should be labeled with the cylinders near each post. the back three cylinders are 1-2-3 and the front three cylinders are 4-5-6.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 24, 2010 | 2001 Ford Taurus
Trying to replace the valve cover gasket on the passenger of my 1987 ford bronco and cannot seem to get to it?
remove the valve cover bolts. remove the valve cover. scrape off the old gasket material off the cover and the engine. put the new gasket in place and replace the bolts and tighten...dont over tighten.
May 23, 2009 | 1987 Ford Bronco
1997 Ford Explorer, whining sound when put in reverse
HAVE YOU TAKEN YOUR FORD BACK TO THE PEOPLE WHO REBUILD YOUR TRANS. FOR A 300 MILE TEST DRIVE? I HAD THE SAME PROBLEM AND COME TO FINDOUT THE TRANNY WAS LOOSE ON THE END AND THEY WERE ABLE TO FIX IT AGAIN.
Jan 23, 2009 | 1997 Ford Explorer AWD
JVC AM FM CD DET FACE CAR STEREO Logo
69 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
