Question about Maytag Neptune MAH5500B Front Load Washer
Replace drum bearings on a Maytag MAH5500BWW
How many hours does it take an experienced appliance service technician to replace the outer tub and lip seal. Factory flat rate hours.
  • tedin2 Mar 21, 2009
    loud noise, almost a roar during the spin cycle
  • 447 Answers
It depends on the installation. Is the area small?? How long would it take to clear the area for complete dissasembly?? After i had the machine all ready to be taken apart we charge 3 hours. Its not an easy job to say the least. However i personally own the same machine that i acquired and installed the new outer tub and seal. The seal comes with the new tub.
Posted on Nov 17, 2007
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
Water leaking from bearing at back of drum
you better get at this soon,the lip-seal is gone from the outer tub and now water has penetrated the bearings behind this lip-seal,the longer you wait the harder it will be to remove these bearings and if its a plastic outer tub you can destroy this tub when removing the old bearings,the inner tub needs to be removed,the rear access needs to be open the motor pulley removed,the c-clip that secures the outer bearing needs removing then the inner tub can come out the front to access these bearings for replacement
Mar 24, 2011 | Indesit W 123 Front Load Washer
Machine makes noise during the spin cycle. Sounds like a bad tub support bearing.
your rear tub support bearing "lip-Seal" has gone out and you need to replace the Lip-Seal and at least the inner bearing,I normally do them both,because it takes a long time to remove the drum and rear access pulley to replace them and if theyre rusted it can take up to 4 hours to replace them,so just do them both and the seal
Aug 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Where can I get drum bearing for MAH5500bww?
Hi, Unfortunately you can't...by itself, or at least that is the short answer. If you have the means of matching that bearing up with a bearing making company then hypathetically you can get it. However, through appliance part sources you have to purchase the entire rear wall/outer tub assembly ( #22004465) and if the bearing is gone, likely the spinner support as well. ( # W10181639)I did quite a few year's ago on the first generation MAH3000's under Maytag warranty, it's quite a big job. If you'd like to check it out go to searspartsdirect, ap wagner, or any number of on-line parts supplier's. You should then witness what I mean, as soon as you identify the bearing as a individual part and click on that number you'll automatocally be directed to the complete outer tub rear wall component's. Sadly it is the way thing's are done these day's. I sound old, but I remember being able to rebuild anything ad long as it was built in north america. Such is modern life with a "global economy" I guess. Hope that answer's your question or help's in some way. If so please remember to leave a rating of the answer I provided here at fixya. Thanks for visiting fixya and good luck with whatever you decide.
Dec 09, 2009 | Heating & Cooling
Very loud spin cycle
The link below, courtesy of www.repairclinic.com, shows that the rear bearing comes with the outer tub only and is very pricey! I have been unable to find a service agency that offers just the bearing. Very aggravating. www.maytag.com would be a good place to define your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MAH5500BWW-%3d%3di1119942&PartID=1119942
Jul 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE FRONT LOAD WASHER MAH5500BWW
Central bearing and seal are damaged. Very expensive repair and very expensive parts. Maytag does not sell bearings separately, they're only available with the outer tub, which is $400-$500; Repair itself is another 2-3 hours of hard work. Do the math...
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Grinding noise
The Neptune bearings are an interesting breed... Maytag wants you to replace the whole outer tub which includes the bearings installed for $180 or so. You can replace the bearings yourself. See www.tonytool.com to see how it is done. The tool costs $379 or so... but it is designed for the service tech. not the d.i.y.er. But watching the video can give you an idea of how to do it yourself. The bearings were available on www.neptunewaxmotor.com for about $35.00. You will also need the Maytag seal kit 12002022 to complete the job whether you decide to replace bearings or the outer tub.
Jan 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
2,421 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
