Is there something that can go bad other than the motor?
Check your warrentee. Call Maytag!! When you see the ads the guy is always sitting around waiting for a call. Maybe we should get him off his B--. They may have a longer parts and labor guarantee than most?
The cost of repair versus replacement needs to be considered. To have the work done I would want a not to exceed quote!!
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
SOURCE: my fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
SOURCE: Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
SOURCE: Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
