Question about Acer Aspire M1641-U1521A PC Desktop
When unit boots-up error message appears "windows shutdown to prevent damage to computer". Code Stop:ox0000007b (oxf78a2524,oxoooooo also. System locks up unable to check for virus etc.
  • 121 Answers
Boot in safe mode and restore it when it was working fine
Posted on Jul 14, 2009
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
Message displayed- problem detected and windows has shut down to prevent damage. Restart using safe mode-tried this but it did not work. Tech Information STOP OXOOOOOOED Unmountable-_Boot_Volume
If this is a corruption it may be fixable, again this depends upon your version of windows, however please be aware this may be a corrupt hard drive so you may need to replace this and reinstall.
Try this first
  1. Start your computer by inserting the Windows startup disks or the Windows installation disk if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
May 11, 2011 | Dell Computers & Internet
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
Stop 0x0000007b (0xF78A6528, 0xC0000034,
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
May 14, 2010 | Microsoft Windows XP Professional for PC
Blue Screen on Windows XP
Sometimes there are conflicts that cause errors to show up, I am glad you mentioned that no new hardware or software have been installed. That helps to rule out some things. At this juncture, if it only occurred once, reboot and don't worry. If you see it again, it will most likely tell you a error occurred at such and such a place and the computer will now shut down. If this happens try to write down the offending part or error and contact us again. However, it is always prudent to backup your computer. You can go in to the setup and look in you event log to see if it was a heat event that will cause your computer to shut down. Should this screen appears again, try the following:
Check to be sure you have adequate disk space. If a driver is identified in the Stop message, disable the driver or check with the manufacturer for driver updates. Pay attention to the video adapters.
Check for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Start up Options, and then select Safe Mode.
Tech Information:
*** STOP: 0x0000007E (0xC0000005, 0xF85F9AD9, 0xF898B7A4, 0xF898B4
please leave me a rating...
May 15, 2009 | Microsoft Windows XP Professional
Is it a bad mb ?
If the HDD is not recognized in the BIOS, windows will not be able to install on that drive. Did you move the HDD interposer from the old drive to the new one? (t is a small adapter that plugs on to the pins of the drive.) If you did, reinstall the interposer on the old drive, ensure it still works. If neither drive functions, then you may have a bad motherboard.
0x0000007B normally occurs when you try to install an older version of WIndows XP on a system with a newer HDD controller and the XP CD doesn't have the correct driver for the HDD controller. So if you get an error like this after getting the HDD to be recognized by the bios, then you may need the HDD controller driver too.
Mar 21, 2009 | Dell Inspiron B130 Notebook
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
Mar 12, 2009 | Dell Latitude D600 Notebook
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Boot problem
Was the operating system installed on another computer? Or a computer with different hardware? If so the drivers for the hardware are not configured properly on the HD or in the BIOS. If this is the case you should format the HD and re-install the OS.
Aug 15, 2006 | Jetway N2VIEW Motherboard
Acer Aspire M1641-U1521A  PC Desktop Logo
319 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
