Question about ASUS P4S800D-X Motherboard
When i boot my pc up it loads the windows xp screen and then it goes blank any ideas of what it can be please
  • 390 Answers
Hi
try loading in with the safe mode and check to see if you have any errors also there might be any issue with change in resolution or refresh rates try taking out the video card and placing it back in this should work..... else
there is a small task that you may have to follow (this will only repair windows and does not take away any settings but if u r not too sure then take some assistanc efrom someone who knows how to)
1. enable 1st boot device as CD, 2nd boot device as HDD0
2. place the Win XP CD and Power on
3. it goes to the windows setup and asks for repair or new install
4. here select new installation
5. then it will follow a few things then later after that it will check for any already installed versions
6. now select the drive in which ur XP is and select repair
this will reload the windows necessary files again and after all the process when it restarts take the CD away from the drive and let it boot
after complete installation windows will load with all the old settins and all
and u r back in business
cheers
pls rate if this was any help
Posted on Jul 14, 2009
  • 49 Answers
Try doing it safe mode see what happens//oz
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
Samsung r40 not loading xp
If the computer boots in to safe mode fine, you more than likely have a virus or spyware interfering with the boot process.
Windows also could have corruption on it.
Insert your windows XP CD and boot the computer, you may need to set your boot order in BIOS so tht CD is first.
Once the CD loads Run the recovery console Select 1 for the C: drive if it asks for a password this is generally blank or will be the password on the "Administrator" account you see when you boot to windows in safemode
Once in the recovery console do a chkdsk /f command
This is will check for errors on the disk and can fix a lot of boot issues
I would also suggest typing the command mbrfix to replace the master boot record.
If it still will not boot you may need to reinstall windows xp
Nov 02, 2009 | Computers & Internet
Dell Inspiron 6000 about 3 years old. When I boot up, sometimes it goes through the early Windows XP screens and then goes to a blank screen. It indicates that activity is going on but cannot see it on the...
The screen cable is most likely damaged. Try connecting an external monitor. If it works, you need to take the computer to a repair center to have the cable changed.
Aug 24, 2009 | Dell Computers & Internet
Blank screen after boting up
There should be a display toggle key on your keyboard. This will toggle the display from the external display to the laptop lcd. Try pressing the Fn + F5 key to toggle the display.
Jun 10, 2009 | Acer Extensa 5620 Notebook PC
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
Blank/Black Screen Asus PC 4G
When you first turn on the computer, start tapping the F8 key to bring up the safe mode screen. You have a very short window in which to press the F8 key before XP loads, so it is possible to miss it. If this happens, just restart it and try it again. Once you are on the safe mode screen, select the enable VGA mode. This will boot your computer to a default 640 x 480 resolution so you can change it back to normal.
Thanks and please don't forget to give this solution a fixya rating.
Jan 26, 2009 | ASUS Eee 4G Notebook
Blank Black Screen After Windows XP Loading Page
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
My windows does not boot it goes to a repair option or starts windows normaly if i choose either one it juct goes to a load screen and after it loads the screen stays lit up but it goes blank nothing on...
Hi jime;
what operating system are you using? is it XP? what recent changes did you do to your pc? software or hardware installed?
open up your pc and re-seat your RAM. and see if you can boot up. Or upon booting, tap F8 and select Last Known Good Configuration.
here is the link below and try #10,
http://articles.techrepublic.com.com/5100-10878_11-6031733.html
hope its helpful,i often do this if my pc gets the same problem
Jun 23, 2008 | Toshiba Computers & Internet
MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
ASUS P4S800D-X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
