What the problem sounds like is that the machine and print driver are set to diifferent paper types. One says plain paper and the other bond paper. Or something like that, the machine says bond and the printer plain paper. Chech the size setting and paper orinentation. Most of the time the paper type is wrong. Also check paper color etc etc. Something between the machine and driver is mismtached Check this : https://printerguidelines.com/
for em-530
"Make sure your keyboard setting is correct. If using standard 411 daisywheel, the keyboard setting should be at KB I. It is also possibleyour daisywheel needs resetting. Turn the machine off for 10 seconds and turn back on. If the wrong characters continue printing, change to a new daisywheel. If problem persists contact your Authorized Brother Service Center.
You may have to do another alignment of the printer.
Do a Clean the Print Cartridge cycle first.
This will allow the printer to print a good alignment page.
Go to your printer, right click, choose properties or preferences, main tab, and restore defaults.
Advanced tab too.
(( tab at bottom restore defaults ))
click this, you will get standard A4 prints.
hope this helps
Regards.
Since it happens with all your printers ,this tells me that it is not a printer problem.
SO....
Lets look at the application..
The first label sees it as PAGE 100 and if you print 50 it should count up to 150.
look at the application and edit it to turn off page numbering .
1) The ribbon cartrige it warn out or damaged, leading to no ink in a particular area.
More likely
2) The print head is damaged or warn out or is not connected correctly to the pritner. The print head may need to be reseated or if this does not fix the problem the print head may need to be replaced.
