Question about Canon FAX B155 InkJet Printer
How to clear printer headfitted new catridge now prints like ink is finished
  • 49 Answers
Go into the program there is a maintance section and some other options//oz
Posted on Jul 14, 2009
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at http://www.lexmark.com. You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Sep 20, 2011 | Lexmark Interpret S405 Wireless All-in-One...
The RED light is per menantly on when the toner has run out. I fit a new "samsung "toner catridge but the red light stays on and the printer keeps asking for a new toner and will not operate
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 09, 2011 | Samsung ML-2851ND Laser Printer
Printer is asking to replace black catridge when u do so message still says replace black catridge even if u take all the colors out still says the same message
Jan 25, 2011 | Brother DCP-330C All-In-One InkJet Printer
I have installed a new pg 30 print cartrige in my Canon MP 470 printer and I get a U051 Error print Head is not installed error. How do I reset printer to fix this error?
Hi there !
The ink cartridge is not properly fitted or installed or does not detect the ink catridge, remove again and fitted it correctly.
Also, clean with alcohol the gold chips of the ink cartridge and maybe there is sticky residue when you remove the sticker. Turnoff your printer and plug it on again to refresh the memory.
I hope it helps you.
Jan 13, 2011 | Office Equipment & Supplies
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Words are not printed clearly in black ink. strokes through them
Your black ink has finished, try and get a new black ink catridge, remove the black ink to get the no on the catridge. good luck
Aug 24, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Faint print out despite ink level not finish
is it a refilled one or not? try changing the catridge
Jul 09, 2009 | Epson Office Equipment & Supplies
My printer is epson fx 1170 it prints half word
this is due to catridge problem,
1.remove your catridge, use cleaner solvent to wet the head of catridge for 2mts and wipe it or clean it with tissue paper
2. check your catridge has ink or finish..
3. due to dry head and not enough of ink, this type of problem comes frequently
Jun 23, 2009 | HP Photosmart C6380 All-In-One InkJet...
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Canon FAX B155 InkJet Printer Logo
113 people viewed this question
old marine
old marine
