Question about Meade LX200GPS Telescope
Sotfware "Autostar" support (With Telescop LX200ACF)
Dear Sir,
I wan to use the software AutoStar for view the sky and the objects on it.
In the database of this software I read and find a updater follder, in wich include the TLE (following to directory: C:\Program Files\Meade\AutostarSuite\Updater\Ephemerides\downloads)
Ex:
METEOSAT 5 (MOP 2)
1 21140U 91015B 05249.77509646 .00000027 00000-0 00000+0 0 9592
2 21140 7.7546 62.5042 0001341 180.0736 85.3335 1.00269531 55387
NOAA 12
1 21263U 91032A 05249.32119333 -.00000105 00000-0 -25848-4 0 2277
2 21263 98.7070 239.1456 0012515 189.8668 170.2272 14.25465606743809
METEOSAT 6
1 22912U 93073B 05247.70409064 .00000069 00000-0 10000-3 0 109
2 22912 4.9772 75.2029 0001247 287.7368 244.3324 1.00281926 41610
But in the menu of the software I do not see them (the satteline).
Can You help Me explain on this problem ?
What I can do to import these objects in the menu of the software to view them?
Thank and best regard,
  • 3,186 Answers
The objects are updated using the Autostar Suite software ver.5.5 on the Meade web site (free).
Here- http://www.meade.com/support/downloads.html
Posted on Jul 16, 2009
Hello my name is greg i have a lx200-acf from my dad when he passed away do not no howto use it ?
This is a great scope. I have a much smaller version :)
1. Take it out on some dark night. 2. Let it auto-align 3. Select something to look at using the AutoStar II 4. Press Go.
Gander at the wonders of the universe.
In the AutoStar, there is a program called Sky Tour. This will pick some things out for you.
Start with a "wide" eyepiece - to see more of the sky. Work your way to high powers as you need or as sky conditions permit.
Goto a few local "star parties".
Jun 02, 2011 | Meade 12 Inch LX200ACF Advanced Coma Free...
ETX-80 hand controller say's "Self Check Failed"
You may need to reload the firmware by following these instructions for Safe Load:
From the Autostar 2.0 README file: "SAFE LOADER MODE IN YOUR Autostar:
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software (version release 1.1G and above). To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar."
This is for the 497 controller. There is NO safe load for the 494 controller.
Nov 01, 2010 | Meade ETX-80AT-TC Telescope
I can not get my Telescope to focus so a picture appears!
You should read the manual - available in the customer service section at meade.com. This is s 'D'eep 'S'pace 'I'mager, so it is geared for faint objects using long exposures (30 seconds and longer). Focus by locating a bright star in the camera, and adjust the telescope focus control for smallest star image. Then move to object wanted to photograph, and begin the long exposures.
Mar 15, 2010 | Meade Autostar Suite Autostar Suite...
Etx-ls update to 1.2g failed, how to i restore or try the update again the autostar iii handbox does nothing
Easy.
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software. To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
Oct 08, 2009 | Meade Optics
I lost the cd for my autostar, how can i get a new cd and instrution book..
All programs and manuals are available for download from Meade.
www.meade.com
Sep 08, 2009 | Meade Autostar Suite Autostar Suite...
No horizontal movement of autostar
Here is Meade's manuals web site--
http://www.meade.com/manuals/index.html
They also have a customer support phone number-
www.meade.com
Either the gear is loose and not engaging or is broken-- or the clutch is not engaging when you tighten the base.
May 19, 2009 | Meade Autostar Suite Autostar Suite...
Autostar software
Check the operating manual for the camera - you may be saving the image with the wrong selections. Most astronomical cameras have 'dark field' and 'flat field' exposures that are used together to compensate for sensor and telescope variations. The 'dark field' is to find hot pixils and the 'flat field' is to get the uniformity of the telescope/camera combination. Together, they are used to correct the image and produce a final image.
Oct 25, 2008 | Meade Autostar Suite Autostar Suite...
Computer control and pointing with NorthStar Goto & Autostar
Your reseller is correct. The wire (Meade cable #505) goes from an RS232 serial port on PC to a 4pin RJ plug. This plugs into the 2nd socket on the bottom of an Autostar 497 handset, the other socket being used for the curly lead to the telescope. So it goes PC to Autostar to telescope.
A common error is to try plugging the serial wire into an "AUX" ort on the telescope control panel - same connector. Not only does this not work, it can cause a lot of damage.
Wired like this you can control the scope from Meade's Autostar Suite (or many other planetarium softwares). You can also update the Autostar software to the latest 2009 version.
What else can go wrong? Well, many people want to control from a laptop, and modern ones don't have RS232 serial ports. Then you need a USB-to-serial convertor dongle, which effectively add a serial port to a laptop. But they often give it a very high port number (eg COM17) that the planetarium software does not find. Use Control Panel to reset the USB-serial-port to COM 1, 2, 3 or 4 and all should be well. But it can be a right fiddle!
Apr 01, 2008 | Bushnell NorthStar Goto 100mm 788840...
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Meade LX200GPS Telescope Logo
91 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
