Question about NEC 80573 Corded Phone
How do i preprogram phone #'s into nec bds 22-btn phones part # 80573
Need to reset the security code for part #80573
NEC has many products, so I don't know what 80573 is, but you should have a system manager who can blitz the old security code so a new one can be set up. Usually that task goes to the office manager, or internal IT person.
Mar 11, 2016 | NEC Lands Phones
Put lines in double hold
If it is under warranty then return it. if you alter it they won't honor it. however you can check that your wires are hooked up correctly from the phone to where it comes into your building it sounds like that is more likely the problem. your telephone provider is responsible outside of your building if they come in they will charge you. we have had a bad line in the past and had verizon put 2 numbers on one line temporarily maybe thats the case. if you don't call them to change it back they won't. Hope this helps
Aug 15, 2013 | NEC 22 Button Display Phone, 80573 (, Two...
I have a NEC 80573 -- how do I turn off the DND feature?
Press the MIC/DND button until the light goes out
Carl
Aug 27, 2010 | NEC Lands Phones
How do I program caller ID to work on lines 4 & 5
caller id must be set up through your phone provider, (beware they normally charge a monthly fee for the privilege.
Thanks )
Jun 19, 2009 | NEC 80573 Corded Phone
User Manual Requested
After much searching, here is a site that should help with this phone.
http://ws1.necii.com/ds2000/d2kdownloads/d2k%20files/product_description/80000pdg04.pdf
good luck!
Bruce
Jan 18, 2008 | NEC 80573 Corded Phone
CHNAGE GREETING
here is how i got it fixed
press voicemail
push SA
then I
mailbox number should be 802
then L is to listen, R is to record a new one.
hope that helps
Nov 27, 2007 | NEC 80573 Corded Phone
NEC 80573 Corded Phone Logo
1,329 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
