Question about Yamata FP202L Cordless Iron with Auto Shut-off
Our steam press will not heat up. Where can we take it to get fixed?
How can I get my Domena SP400 steam press to produce steam
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Apr 21, 2014 | Irons
Phillips double-speed 2.5 bar reservoir heats but will not steam
Thermistor is probably damaged, and the machine does not identify that the steam is ready (max temperature was reached) and pressing the steam button wont do anything. Change the thermistor (should be carried out by professional technician).
Jan 04, 2013 | Philips Irons
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 14, 2012 | Irons
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
For my singer electronic steam press esp2 can i use deironise water instead of distilled as i can not get any distilled water in any of the shops in my area.
You can try the deionized water but you may have trouble with it producing enough steam...water that is too pure may not produce steam well depending on the way it is heated.
If it does not produce enough steam just add a bit of salt to the water and it will work well.
heatman101
Aug 13, 2011 | Singer Electronic Steam Press
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
No steam. I pressed the steam button on the underside of iron handle and no staem.
There 's a leaked capacitor in the circuit board. You just have to replace it and it works again.
Please visit the following page for detailed instructions:
http://thechipfreak.blogspot.com
Jan 15, 2010 | Rowenta DG5030 Iron
Singer steam press csp-1 iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Mar 03, 2009 | Singer Electronic Steam Press Iron
Yamata FP202L Cordless Iron with Auto Shut-off Logo
119 people viewed this question
Top Yamata Irons Experts
Are you a Yamata Iron Expert? Answer questions, earn points and help others
