Question about Sony BRAVIA KDL-40V3000 Television
Cannot fill screen with normal picture size setting
I bought the sony kdl 40v300 and connected to time warner scientific atlanta hd dvr box with component video cables. I set up the box to allow all available broadcast formats from 480 to 10180i. Problem is that the picture size on hd broadcasts like espn hd do not fill the screen or are distorted/stretched. The proper picture can be had on the "normal" setting for the tv, but it is shrunken with borders on all four sides. If I select wide zoom, the picture is distorted/stretched with thin bars at the top and bottom. I have tried to adjust picture size using the cable box but all of the adjustments are disabled. Only the sony picture adjustments work but none of them achieve proper picture size, full screen dimensions. Please help.
  • 4 more comments
  • trooney123 Jan 01, 2008
    I have exactly the same problem as jkelly7680. My equipment is Sony KDL-40XBR with comcast Motorola Set Top Box with DVR. Would appreciate any help. Thanks
  • Anonymous Feb 18, 2008
    Opposite problem with Sony KV32S42- My picture is too big. I can't read the close captions as they are off the bottom of the screen and peoples heads are scalped off the top of the screen. Adjustments on the menu do not solve the problem
  • Anonymous Mar 18, 2014
    I don't have the remote. How do I make adjustments to picture size using buttons
  • Anonymous Mar 19, 2014
    My picture is not filling up the entire screen. what changes do i need to make to my settings in order for the picture to fill the screen?
  • Anonymous Mar 31, 2014
    picture jumps from normal to zoom and will not stop. Have reset TV to factory defaults, used WEGA gate to reset picture size and still jumps ??
  • Anonymous Apr 01, 2014
    I have adjusted picture using all settings available but picture does not fit well in screen, too large cutting off words on the sides
  • 1,554 Answers
Assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
now check your tv settings to accommodate
Posted on Feb 18, 2008
  • Jody
    Jody May 31, 2014
    what about Direct TV?
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
Screen goes black and resets during HD shows
Have you already tried to power cycle all the devices? Unplug the power cable on all your devices for about 1 hour then plug it back in. Check if that fixes it.
Aug 31, 2008 | Sony KP-53HS10 TV
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
Picture shifted to the lift
Press menu on remote and tab over to settings
Scroll down to tilt correction
Sep 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
Aug 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Shifted Picture
Yes. This problem comes about by actually pressing the center ring accidentally during normal viewing. Just press and hold the left or right side of the ring until the pciture straightens itself out again (if the black portion of the screen is to the right of the picture, press the right ring; if it is to the left side, press the left ring).
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 51PW9363 51" Rear Projection...
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony BRAVIA KDL-40V3000 Television Logo
2,454 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
