Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna YTH2448 engine leaking oil
I have a 3 year old lawn tractor w/ 220 hours on it. It's recently started leaking oil, which appears to be coming from the seam in the engine just about the oil drain. It's a steady leak, but the oil level doesn't seem to drop (according to the dip stick).
What's the likely cause and fix?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
That sounds like the sump gasket is leaking, sometimes the briggs machining at the sump and head areas are a little rough and a bad fit can allow the gasket to blow,if it is leaking it is actually sucking air in rather than pushing oil out while it is running. You would have to drain oil, remove the engine turn it upside down,remove the oil pump cover plate( 3 small screws) pull oil pump rotor and drive shaft out,remove sump bolts,replace gasket and reassemble.Be sure to use a light coat of gasket sealer like black silicone.
Posted on Jul 30, 2009
    Problem Solver:
  • 5 Answers
There is a bracket on the trans axle release valve that easily rusts and will not open or close fully. Remove the end plate with the hitch (4 bolts) and spray the bracket lever on the trans axle with some rust buster penatrent. Work it back and forth until it moves freely then grease it. Re-assemble and you are ready to mow.
Posted on Oct 01, 2009
Husqvarna YTH2448 wont stay running
clean or replace the carburetor. sometimes they are cheap enough that it is worth replacing over trying to clean it. if it starts and runs for a few seconds then it is a carb issue. if it takes time before it dies then it is something else
Sep 26, 2013 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
I have a 21 HP Kohler engine in my 2007 Sears 42 " lawn tractor. I did the 100 hour tune up last year. It's been fine up until this week when I would notice a puff of white smoke towards front, possibly...
Oil will be drawn into the engine under heavy acceleration, irrespective of load. Check this before you worry! You might also check for any external leaks of oil or hydraulic fluids around the exhaust area which could cause white smoke at odd intervals.
Good luck
Aug 27, 2013 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Briggs Stratton 24OHV ELS725
most all small engines have the same bolt pattern but a lot have different size crankshafts i have a 25hp on craigs list in hartford ct farm section
Jul 07, 2012 | Husqvarna Garden
My husqvarna YTH2448 with BS 24OHV ELS725 started knocking and leaking oil from right side. I guess it threw a rod? I want to get another 24HP motor and replace it. Will any other motor's bolt pat
most all motors will boltt up u need to make sure the crank is the same diameter and length besides even if it didnt bolt right up u can always drill new holes
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How to reset oil change indicator on my husqvarna riding lawn mower
depends on how old the mower is, for the past 3-4 years, Husqvarna made it so that you have to replace the unit, unable to just reset it.
Jul 02, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,941 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
