According with a manual I found online:
1.- Press the MENU button on the remote control.
2.- Use the cursor down button to select Installation in the Settings menu.
3.- Use the cursor right button to enter the Installation menu.
4.- Select Language and enter the list of available languages with the cursor right button.
5.- Select your language with the cursor up/down buttons
6.- And press OK to confirm your selection.
SOURCE: 4 blinking red lights
From what I am able to find out there is a problem with the main power supply or thermal shutdown when the lights are red flashing. have you tried to reset it?
SOURCE: philips model 37pf9431d/37 no picture
This seems to be complicated.
Best would be to get it fixed by Philips itself.
SOURCE: Philips 60PP9200D/37 60-Inch Widescreen Rear
You will need to purchase the small signal board......they are kind of difficult to remove and replace. They sometimes look like a small aluminum sandwich box or they look like a video card out of a computer. Read the instructions to replace and reprogram this. Look up at the Philips Partstore.com. Type in model # and see small signal board......These canbe pricey $$$$$$$$
SOURCE: MY 60 INCH PHILLIPS 60PP9200D/37 WILL NO POWER
If the front power light does not come on check the fuse in the back of the Tv.
