Question about Sony Cyber-shot DSC-W50 Digital Camera
Lens Shutter stuck
When I turn my camera on often the cover of the lens does not open all the way, It goes about half way and then sticks. It is almost like there is something sticky on the lens? When I turn the camera off, it closes all the way-but very slowly. Any ideas? Do I need to clean it maybe? If so how!!?? :-(
    Scholar:
  • 71 Answers
I wouldn't recommend taking the camera apart and trying to clean it yourself. There's lots of tiny parts and screws in there and most people don't have quality tools to get inside of there without damaging something else.
These guys are fast and good, but a tad expensive.
http://www.precisioncamera.com/
Posted on Nov 17, 2007
Sticky shutter inside the lens
Not sure that you really mean shutter, or the automatic lens cover. See the description below for a stuck shutter. If that's not what you meant, then see this instead. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 05, 2011 | Olympus Cameras
My camera goes on and my menu button works, but the LCD is totally black and it looks like the lens cap is still on, but it's not
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 23, 2009 | Canon PowerShot S2 IS Digital Camera
LENS PROBLEM
The slightly open shutter is the reason for this problem. Thank God you mentioned it.
Solution: Try with your fingers to shift the shutter “blades” back and forth to see if they move freely. If they do no move freely it maens the shutter “blasdes” and stuck by particles/dust/something. So you just continue to shift them like that untill they are free again. Once they are free turn your camera back on and it should perform as normal.
Sep 18, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Shutter won;t open
Are you talking about the shutter, or do you really mean the automatic lens cover ? Take a look at this first to see if this is what you meant. Make sure you read the comments also for additional tips. I don't think it will be necessary to open it up to fix it. Stick with the easy tips, they should work, especially if this is happening occassionally:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 05, 2009 | Canon PowerShot A570 IS Digital Camera
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Lens cover jamming
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
Aug 28, 2006 | Samsung Digimax 250 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
101 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
