Question about IBM eServer xSeries 336
IBM SERVER XSeries 336 update bios & firmware , which update express cd working
  • 58 Answers
SOURCE: Install windows xp on a IBM xseries 200 8479 computer
You have to download the scsi driver from the ibm site. You'll need a floppy and floppy drive. When you boot with your xp cd to setup press F6 to install driver.
Link to your IBM. Since IBM have different models you have to type it at the provided link.
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/brandmain?brandind=5000008
good luck
Posted on Dec 21, 2007
  • 13 Answers
SOURCE: server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
Posted on Nov 26, 2008
  • 93 Answers
SOURCE: SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Posted on May 19, 2009
wiqi546
  • 1511 Answers
SOURCE: We have lost IBM xSeries 226 server's Driver CD.
Sir, Here are some drivers which may help you out.
You can also do a manual search on Ibm's site.
Here is what i found there.
Kindly Do Rate, if helpful.
Posted on Jul 18, 2009
SOURCE: hi, can IBM xSeries 336 supports Hyper-V?
ftp://ftp.software.ibm.com/systems/support/system_x.../25r4613.pdf according to the above link, seems to be able...
Posted on Apr 06, 2010
Why xseries 336 has blank screen, starting but not booting
If your computer won'r boot, you have a problem with your Hard Drive or the boot system of your drive. You should have an emergengy disk/CD to access your computer for this case and repair boot or check integrity of your drive. No way to help you by answering a question
Sep 04, 2014 | IBM eServer xSeries 336
System has Blue Location, and Orange Power led lit but system wont power up, no error codes displayed on diag panel.
Please remove the BIOS battery and then place the BIOS jumper and reset the BIOS. Please check jumper position in motherboard manual. Then, try again. It will power on.
Please let me know if it stil not worked.
Regars,
Kaushik Patel
Oct 30, 2013 | IBM eServer xSeries 336
X series 336windows instal
You reqiure IBM Server Guide setup disc to install windows OS
You can download image from below link
Burn image and boot from it. You will able to install windows
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=migr-56685
Regards,
Fiyaz
Mar 18, 2013 | IBM eServer xSeries 336
Problems with IBM Xseries 346 Server
Check Light Path Diagnostic which is located on the front side of server . It gives a clue of what's the issue . If you can't see any amber on Light Path Diagnostic , then its an indication of max logs logged on BIOS event logs. You may need to restart server > Get into Bios and clear all event logs . This would remove the information sympol from server .
Jul 31, 2012 | IBM xSeries 346 Server
I have a Xseries 345 server and the USB port is not working
Update bios, reinstall Chipset driver else use external USB PCI card
Apr 02, 2012 | IBM xSeries Computers & Internet
Steps to configure raid 5 on ibm xseries 232
hi,
which material have you ? : CD
which server ? xseries xxx model type ?
If this is the unique SCSI adapter in your system
or the unique seen, you must:
0) download
90p2772.iso 505,085,952 IBM ServeRAID support CD v6.10
or use what you have.
1) Boot from cd (linux) to configure RAID , before install W2K Server
2) run 23k4684.exe (previous site) in another pc and make a floppy
3) boot from W2k CD and press F6 when proposed
4) insert floppy previously made
5) when OS is installed, or from CD or using 23k4687.exe,
install "IBM ServeRAID Manager", to see activity.
Oct 28, 2010 | IBM eserver xSeries 232 8668
We are using IBM X226 server with 4 GB RAM & 146 GB SCSI HDD. We are using it for ERP application . It is very slow . When HP proliant ML 110 server with 2 GB & 160 GB SATA is used in its place it...
strange. with 4gb of ram, it should be fast. try to install better version of windows like win 7. it could help you. just don't install vwindows vista cause is slow as hell. let me know if it worked
Jun 28, 2010 | IBM xSeries 226 Server
Hi, can IBM xSeries 336 supports Hyper-V?
Apr 06, 2010 | IBM eServer xSeries 336
IBM xSeries 360 Server support Win 2003?
The good news is IBM says it will work, the BIOS might require an upgrade. I would consult ibm.com and get the latest updates for your hardware after that insert CD and reboot!
Have Fun.
Jul 23, 2009 | IBM xSeries 360 Server
IBM eServer xSeries 336 Logo
1,267 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
