Question about Panasonic CX-DP88 8-Disc CD Changer
Hi,i have a Audi A4 1998 fitted with a Delta cc Part 4D0 035192 radio and i want to fit a Panasonic DP88 CD Changer from a later model Audi to the radio.The original CD Changer was removed for repairs and never returned.Is there a wiring diagram avalliable to do this convertion?Please help.Hennie
5 Suggested Answers
Eagleeyes
  • 199 Answers
SOURCE: volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Posted on May 03, 2007
Eagleeyes
  • 199 Answers
SOURCE: 2006 toyota solara cd changer
hi, it is very very strange. can you send a pic of the scratches? would be interested to see where they are and what they are like
mark
Posted on Oct 22, 2008
SOURCE: I WANT CHANGER MY PANASONIC CD CHANGER WITHOUGHT REWIRING .
I'm replacing my Panasonic CX-DP801 8-Disc CD Changer with a Panasonic CX-DP 880 Changer.
Problem is I cannot use the existing CX-DP801 harness and want to know what adapter I will needin order to utilize the 880 changer.
Posted on Apr 09, 2011
SOURCE: I have a Panasonic DP801
Two methods.
1. Remove three screws from each side and the mounting brackets (if applicable). You will have to pull the sides away from the rubber mount vibration dampner things and on the back there s a slot that says "open" where you will need to stick in a screwdriver and gently pry it open. You will also need to push a small screwdriver in the 3 slots on the top and bottom holding plastic clips that secure the front cover. This will let you pull of the plastic front cover. Once you have the cover and the sides and top off, you have to push the 4 spongy rubber supports in toward the unit. They will fit through the little hole. Then you need to carefully remove 2 springs (1 on each side attached at the center/top of each side) that supports the unit weight. Then you should be able to carefully rotate the player toward the back until you are looking at the bottom of the unit. There is still a ribbon cable attached at this point so don't drop anything or it will break. There is a large plastic geared wheel showing on the bottom. spin that wheel with your fingernail to make the CD retract into the magazine. Once it is in the magazine, there is a black small lever on the bottom near the back of the magazine. this holds the spring tension and as soon as you move the lever slightly to the side, the magazine will eject.
METHOD 2. I know all this because my unit died today and I took it apart. If yours is working, I would be willing to pay for shipping to get your unit to Colorado, I will remove your CD's and mail them back to you if I can keep the working CD changer :)
Greg
evlgreg at yahoo dot com
Posted on Sep 20, 2011
WE HAVE A CD PLAYER IN THE CAR ALREADY WITH A REMOVABLE FRONT BUT ONLY PLAYS ONE CD CAN WE FIT A MULTI CD CHANGER TO THE EXISTING CD PLAYER OR DO WE HAVE TO GET A COMPLETE NEW CD SET UP
several companies have multi disc CD players that are in dash..
and others have the changer in a remote location ( trunk) and are controled by the head unit..
Which model head unit do you have? It could very well fit into the later catagory and support a remote located disk changer..
Sep 29, 2010 | Car Audio & Video
I would like to advise that it would be better for you to update to a universal type adapter that can be easily fitted to your Player. This adapter would be able to play from memory sticks, usb memory or even your Ipod and that means all your MP3 can be easily stored and carried over. The DVD changer is compatible. However I hope you will decide with my advice and check for the models available in your city. So go with the times. Good day
Aug 02, 2010 | Panasonic CX-DP801 8-Disc CD Changer
Lost radio code audi delta cc
Hi I have an audi Delta radio
Radio serial: AUZ1Z4T6416362
Can you please provide the unlock code?
Thanks
May 31, 2010 | Car Audio & Video
I removed my Mercedes 6 disc cd changer from my
Without power. you may just have to disassemble the unit.
Mar 08, 2010 | Panasonic CX-DP88 8-Disc CD Changer
Preplace the charger by another device
Yes it is possible with any cd changer that have RCA jacks behind the radio,
that is your case, you are goin gto install a audio sensing device, when the ipod is on the cd changer will stop,
when the ipod is off the cd changer will play 10 seconds later
this interface is only rca jacks easy to plug behind the radio and you can use any audio source, ipod mp3 sat radio
you can also buy a ipod cable
audio sensing device, it is made for sony, but will work with any rca jacks source, also cd changer must be present all the time, don't remove it
Nov 09, 2009 | Panasonic CX-DP88 8-Disc CD Changer
Cant remove magazin with cds without changer is on power
Is there a pin-hole on the front of the cassette? If so, insert a paper clip into the hole to manually release the cassette.
Sep 08, 2009 | Panasonic CX-DP88 8-Disc CD Changer
Radio and cd changer for bmw m3 e36 ea88906
If you go to www.crutchfield.com they will have a menu for all upgrades to your vehicles sound system including which head units (or stereos) will fit your Bimmer.
~Stillin~
May 21, 2009 | 1994 BMW 3 Series
Audi gamma bose CC unit
I just took a 6 CD changer out of my 1993 Audi with a Gamma Bose CC as well as the adapter box. I am interested in selling it (I traded the car). If you are interested in the changer, let me know and we can exchange contact information.
Apr 08, 2008 | Blaupunkt Car Audio & Video
Volume is uncontrolable
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
Panasonic CX-DP88 8-Disc CD Changer Logo
367 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
