Switch - Panel Dimmer
Special Tool(s)
Radio Removing Tool
T87P-19061-A
Removal
To install, reverse the removal procedure.
SOURCE: 2003 Lincoln Town Car - Power window switch removal/installation
SECTION 501-05: Interior Trim and Ornamentation
2003 Town Car Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 01/28/2002
Front Door Trim Panel Printable View (206 KB)
Removal and Installation
NOTE: LH side shown, RH side similar.
Open the screw covers.
SOURCE: does stering wheel have to be removed to install
No. The steering wheel does not need to be removed to replace the dimmer switch. Remove the screws under steering column and remove the upper and lower panels.
SOURCE: the passenger side low beam
y need new bulb on the passenger side and inst. cluster need to be checked for fuse or bulbs replacement.
SOURCE: replaced instrument cluster 2000 town
Thats correct, the instrument cluster contains the anti theft module , well part of it, it runs through the cluster, you will now need to have it reprogramed at the dealer, the dealer needs to program the new cluster to the cars computer, make sure to bring all key to car so they can be programed at the same time. its getting crazy with these computers and programing.
SOURCE: instrument cluster lights don't light up on my 1993 Lincoln town car cartier model
If the problem is not a fuse the lighting pannel might be burned out.
