Question about Brother HL-2040 Laser Printer
Won't pull paper through. starts to then paper
Won't pull paper through. starts to then paper light comes on. No paper jammed anywhere. Replaced with fresh paper. Still wont pull
  • 32 Answers
Just clean up your paper feed tires witch are below the printer. u have to see it when u pull out the paper try!
Posted on Aug 24, 2009
My paper won't load - it pulls in about 1/4 of the sheet and then stops. I'm getting error code E3 and have checked for a jam but see and feel nothing. I've also used alcohol to clean the...
This is a paper jam error. Unplug your computer from the AC outlet and from the computer, next place the printer on a table or anywhere that you can get access all panels and the paper tray easily. Remove the paper tray and look for any pieces of paper that may be stuck in the printer. Look also around the back as there is usually a panel that can be removed without any tools.and check there. Also open the printer as if you were going to change the ink and look around there. Make sure you have plenty of lighting or a flashlight as even the tiniest piece of paper can trigger this error message.
Hope this helps.
Jul 17, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam! how do i get the sheet out!?
open the toner place and remove the toner so as to remove the remaining papers inside the printer and plow the printer very well
Oct 16, 2009 | Brother HL-2040 Laser Printer
All the lights started flashing after fixed a paper jam
you have take out zamed paper from the printer from the back side of the printer by ejecting the try from back side if it present. or pull out your tonner and then pull out the zame paper.
Aug 22, 2009 | Digital Products Brother HL-2040 Laser...
Brother 2920 Fax Machine keeps jamming every few pages
Please try this and let me know how it goes
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
I had a paper jam..took out the cartridge..pulled
Hello sir;Track back the paper you pull through you will find a senser either stuck or come off, put it back property.
May 06, 2009 | HP LaserJet 1020 Printer
Paper jam message, but actually no paper jam
alternative :
Mar 25, 2009 | Lexmark X83 All-In-One InkJet Printer
Mf8100 keeps displaying paper jam with red light flashing have pulled everything i can possibly find. can not find any jammed paper anywhere.
i used a bit of strapping cable and slid it up between where the paper first goes into the printer from the paper tray and found there was a bit of paper there. that fixed the problem.
Oct 01, 2008 | Canon Office Equipment & Supplies
Can't print - paper light is on
turn the printer off, count to ten, then note the light sequence ie: flashing organge solid orange, flashing green or solid green
Jul 25, 2007 | Brother HL-5250dnt Laser Printer
Brother HL-2040 Laser Printer Logo
197 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
