Question about Welding Tools
Stick inverter does not perform
My Inverter stick welder is not performing the way it should. The start up arch is fine but as soon as I bring the rod closer to the workpiece it start to sputter and stick, it does not matter if it is on the highest setting it still does it. The weird thing is it does not do it so often at night when it is cooler, feels like there is a loose connection somewhere that prevents the continues power from the welder to come through. I don`t know if it might be the capacitor bank? Any suggestions? please help
Regards
Bastiaan
  • baszeedyk Jul 18, 2009
    Thanks for the feedback, I tried what you suggested but it still does the same , sticks and sputters sometimes, and sometimes it is fine, can it be the pot meter where you select the amperage, when it starts to sputer I turn it full amps but makes no difference.
    Regards
    Bastiaan
    Problem Solver:
  • 5 Answers
Hey Man-
Welcome to the world of arc blow--
everything electric and radio on earth has a magnetic pole. which causes your welds to look like bird spank-
depending on what rod or material your welding / use a jumper ground or reverse your +/- leads and see if your gaining on it
Posted on Jul 14, 2009
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Aluminium welding settings
Check your manual or the welding rods data sheet. The settings depend on what you will weld. Consult online manuals and welding charts. These will help you a lot.
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
Oct 07, 2013 | ARC Thermadyne Inverter Stick/TIG Welder...
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
Tusten tip keeps sticking what am i doing wrong i have rockworth inverter
Make sure the tungsten tip is sharp, not too far from the nozzle and try not to let it touch the metal or molten pool. Also make sure you have an adequate gas feed
Feb 23, 2011 | Inverter 220 Volt Tig Arc Welder
Hi I have an electric stick welder ,made by welding industries type mc85 output93amps at 24 volts.Great little machine but it recently got dropped and now doesnt do the frizzzzt thing .The fan works and...
small inverter will not put out the amperage required for welding. if you still have power at the stick and no buzz but a steady melt the rectifier probably crapped out. for light welding harbor freight has a mig thats $90 and will do light jobs decently.
Dec 23, 2010 | Welding Tools
Inverter stick welder welding rod sputters and sticks
It sounds like the rod that you're using is too big. If it is a 110 volt machine, and you're using a 1/8 rod...Then the rod is too big. Try a 3/32 rod.
Jul 14, 2009 | Welding Tools
Welding Tools Logo
80 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
