Wrong IP address
I have a comtrend CT-5621 router. I then connect from that to a Linksyswireless router. Everything worked until I needed to connect to my workserver with my laptop. My work server requires an IP 192.168.1.1. My IPaddress is 192.168.0.1. How do I change my IP address? I typed in 192.168.0.1 to my browser and changed it. Now nothing works.
192.168.0.1
Posted on Jul 14, 2009
How can i cascade a Comtrend CT-5621 with a Netgear Wnr2000v3
works best if you hard wire from LAN port of main router to LAN port on second router. 2nd router never has anything plugged into internet port. 2nd router has dhcp turned off. 2nd router has a ip inside the 1st routers ip range but not the same as anything else
Jul 06, 2012 | NetGear WNR2000 Wireless Router
I forget my comtrend ct524 password
For that you need to secure it with WEP password you can set it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security then enter new password then save settings and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 06, 2011 | Comtrend CT-520 Router
I need to download the driver, where can I download the driver for COMTREND/CT-5071T for a Mac for free?
If you need to configure something on the router, hook to it via ethernet wire to configure it. the default ip address for the router is 192.168.1.1 You will need to assign a static IP address to your wired network card in the range of 192.168.1.x, I would static it to 192.168.1.10 Then after you have staticed your IP address, use a browser to navigate to 192.168.1.1 the default user/password for the router is: username:root
password:12345
You should be able to change any settings then that you need to. Also, any firmware updates you would need should be provided by your ISP.
Apr 29, 2010 | Comtrend CT-507 Router
Im trying to access the interface for my CT507IT router but the problem is that it hooked up to my WRK54G linksys router that we use for wireless. How do i access the interface for my CT507IT router?
You will need to check the IP address of your CT507IT router.
You said that CT507IT is connected to the WRK 54G router. There are 2 router in your network. First let me know which router is connected to the modem ? WRK or CT507IT . The router which is connected to the modem must be the main router. Connect the computer to that main router and check the IP address of that router. Using the default gateway you can access the page of that router. Now connect the computer to the CT507IT and check the IP address and default gateway. use the default gateway number to open the page of CT507IT.
Everything depends on the connections of your network.
Please clarify the connections.
Apr 15, 2010 | Comtrend CT-507 Router
I have a comtrend ADSL2+Ethernet Router hooked to my desktop Pc and a G-Wireless Router made by Belkin.According to the tech I should be able to connect these two to use my Laptops, but any way I've tried...
You dont need a Belkin Disk to set up - this can be done manually you can get a manual from this site http://en-us-support.belkin.com/app/product/list/q/routers/ select G in the first dropdown and then your model - theres two to choose from and then then the version
you have a choice - you could change the comtrend router to just use the modem - bridged mode - they have a few different routers see here http://www.comtrend.com/links/i$residential-adsl2-modem-router$product.htm so not sure which one you have if you can bridge to just use the modem then connect tothe Belkin and all PCs should connect to the Belkin
OR you can connect two routers together Leave the comtrend router set as it is -
Set the IP address of belkin router to same subnet as the comtrend. Depending on the DHCP range of the comtrend router - set the IP outside this range - so if comtrend is set to give an ip of 192.168.0.2 to 192.168.0.100 - set the belkin to 192.168.0.254 Disable the DHCP in the belkin.
Connect the comtrend LAN to one of the Belkin LAN ports - you may need to use a crossover cable. On the belkin the WAN port will be left unconnected
Mar 20, 2010 | Belkin (F5D7231-4) Wireless Router
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Ip router and login name / password
yea but that backdoor got hack so wtf do i do when : user name root psw RM6008 dont working. ?
and wft a Backdoor on a router Who`s so stupid to make that
Mar 01, 2008 | Comtrend CT 300 (CT-300) Modem
Router login
If your Comtrend CT-5621 came with the package from your ISP then it is possible that the username and password has been changed by your provider and you would have to get in touch with them.
In some instances the username is "root" and the password is "root".
Some known passwords from ISPs are:
Canadian Broadband/Aliant - RM60008
NetComm - NetC0mmV3oo
Some ISPs disabled/blocked the web based configuration interface and the initial way to communicate with it is a telnet session to the router.
Would you know if your default IP address of 10.0.0.1?
Good luck and kind regards.
Oct 21, 2007 | Comtrend CT-507 Router
Accessing router
if you have changed the ip address of the pc that is connected to the router, then the router can no longer see the pc because you have changed it manually, you need to change the router back to DHCP enabled to allocate ip addresses automatically and change the properties of your network card to obtain ip address automatically. This way all the pc's will be given ip address to share the network.
Aug 30, 2007 | Comtrend CT-507 Router
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
