Question about Welding Tools
Inverter stick welder welding rod sputters and sticks
My Inverter stick welder is not performing the way it should. The start up arch is fine but as soon as I bring the rod closer to the workpiece it start to sputter and stick, it does not matter if it is on the highest setting it still does it. The weird thing is it does not do it so often at night when it is cooler, feels like there is a loose connection somewhere that prevents the continues power from the welder to come through. I don`t know if it might be the capacitor bank? Any suggestions? please help
Regards
Bastiaan
  • Bruce Hathcock May 11, 2010
    What rod you burning? 6011 7018? what amp rating? size of rod? 1/16 1/8 3/13? are the connections clean? is the ground clamp bolts good? is the rod holder clean? if so then unplug it wait five minutes arc the ground and rod holder next short the plug from the ground to the hots so it will kill the capactors use a screw driver to do this with your glove on. then pull it apart and blow off the cooling fan with air check the capaciter bank and check each wire and spade connectors look for any wire that has the rubber on the wire. let me know if you find it. also check the contats on the inside.
  • 19 Answers
It sounds like the rod that you're using is too big. If it is a 110 volt machine, and you're using a 1/8 rod...Then the rod is too big. Try a 3/32 rod.
Posted on Aug 06, 2009
Aluminium welding settings
Check your manual or the welding rods data sheet. The settings depend on what you will weld. Consult online manuals and welding charts. These will help you a lot.
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Welding rod sticking when striking arc
try striking the rod like a match. keep a good arc, not too long or short. try around 90 amps.
Apr 28, 2013 | Lincoln Electric K1170 AC-225 Stick Welder
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
Broken welds on SS parrot cage. Need to repair ss rods that were pulled out and broke the welds ?
Easiest way to do it it's by using silver solder with oxyacetylene torch or propylne tank. But if you have access to STICK, MIG or TIG machine use 308L type SS welding stick, wire or links.
Feb 09, 2011 | Welding Tools
Hi I have an electric stick welder ,made by welding industries type mc85 output93amps at 24 volts.Great little machine but it recently got dropped and now doesnt do the frizzzzt thing .The fan works and...
small inverter will not put out the amperage required for welding. if you still have power at the stick and no buzz but a steady melt the rectifier probably crapped out. for light welding harbor freight has a mig thats $90 and will do light jobs decently.
Dec 23, 2010 | Welding Tools
Problems with welding with a Forney 180 amp. Arc Stick Welder
check your input power connections on the primary side of the welders transformer, then if its an infinite control welder check that control,otherwise if it's a plug- in selectable amperage check these connections,it sounds like the infinite control is getting dirty and not passing all the current it shows on the control, also double your O.C.V. on the secondary and see if its with-in welder specs
Nov 15, 2009 | Welding Tools
Have a 120 volt 70 amp stick welder what gauge or stick type do i use
1/16th stick to 3/32nd.
3/32nd being the maximum. Don't use 3/32 for an extended period of time, or you can burn up that welder. (Even if it has a fan. If it doesn't have a fan built-in, I invite you to put a house box fan, close to the ventilation slots for the welder)
I would also recommend using 6011 rod. It's a mild steel rod, and is excellent to begin with. Usually used for filling, and medium strength situations. It does splatter, be aware of that.
Not trying to give you a tutorial on beginning welding, but would like to offer some tips:
1.Make sure the ground clamp has a good, clean surface it's clamped to. If not, it will be very hard to get the rod started, and also to keep it going. (Makes bad welds too)
2.Start with a B U T T weld. (Had to type it that way do to censorship of certain words)
That's laying two pieces of metal next to each other, and laying a bead in-between them. Easiest thing to start with. Go to corner welds next, (Two pieces together at a 90 degree angle), then try Uphill welds.
3.Shield flipped up on helmet, welder on. Lay the rod past the area you are going to start on. Past the metal edge. Lay the ->flux coating of the rod on the edge of the metal piece. The tip of the rod is past the metal edge by at least two inches.
This way you are lined up to begin the weld. Then flip your shield down, draw the rod back, until the tip of the rod touches the metal. Once the arc starts, lift the rod up a little to get the correct height, and keep that arc going.
4.Watch the PUDDLE, not the arc! You are watching the melted metal in front of the arc. You need to see how that puddle is doing, in order to compensate by bringing the rod closer, or further away.
5.Use a Zig-Zag pattern to begin with. Keep the Zig-Zag close to each other, until you are comfortable enough to make a longer pattern. Watch the penetration. Good penetration is the key, not a pretty weld.
6.Use the proper safety equipment. If the welding helmet lens has a tiny little scratch, you will burn your eyes. NO fun, believe me!
You won't know it until you wake up the next day with your eyes swelled shut!
Cover your arms, and use welding gloves. Welders give can give you a radiation burn, worse than a bad sunburn. NEVER just start welding a little with No welding helmet. Welding goggles are for the birds, or Acetylene welding!
Be safe, have fun welding!
Sep 02, 2009 | Welding Tools
Stick inverter does not perform
Hey Man-
Welcome to the world of arc blow--
everything electric and radio on earth has a magnetic pole. which causes your welds to look like bird spank-
depending on what rod or material your welding / use a jumper ground or reverse your +/- leads and see if your gaining on it
Jul 14, 2009 | Welding Tools
I am trying to find out what the symbols on the front of the welder mean for the different settings.
there are symbols for stick welding which is a straight looking tube with a rod sticking out there is a position for mig {wire welding}a tube witha nozzel on the end and one for tig { tungstun electricarc torch} which requires a filler rod to feed as you weld and is a tubewith a sunburst looking emblem on the end of it. if this dont help check back with me and tell me what the symbols look like and Ill try to further help you.
May 02, 2009 | Welding Tools
Welding Tools Logo
120 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
