Question about Polar F11 Heart Rate Monitor
My f11 says buttons locked - Polar F11 Heart Rate Monitor
Press and hold the light button for for 2 seconds this will unlock them.
Barnesy
Posted on Oct 19, 2009
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
Aug 15, 2014 | Whirlpool Washing Machines
My laptop, a Satellite #L455, is giving me numbers when I type in letters. This does not occur all the time but often when I'm playing games.
the letter that does is U,I,O,PJ,K,L,M it happens all you need to do to fix that problem is press the Fn buttin and while keeping this down it should be the F11 button make sure you look at the other F button as it will show you a little box with load of dots inside it if it is the F11 button then pressing this once will turn it back to letters this function is for when your doing calculations its easier to use it but some people dont like it you can turn it on and or off by pressing the Fn button and pressing the F11 button
Jun 29, 2011 | Toshiba Computers & Internet
Key board function button locked, I don't know how to unlock
Hi
You could try F11 or FN+F11 this may work look for nulock key
Feb 16, 2011 | Fujitsu AMILO PC Laptops
I somehow locked the buttons on my F11 Polar watch but I cant seem to unlock it???
By pressing and holding the Light button, you can:
Lock and unlock all the buttons, except the
Light button, in the Time of Day display or while
recording your exercise. Press and hold the Light
button until Buttons Locked or Unlocked is
displayed.
Sep 23, 2010 | Watches
I was exercising and wearing my Polar F11 and it locked up. What do I do to get it to unlockl?
This worked for me. From the manual, "If there are no reactions to any buttons, reset the wrist unit by pressing all the buttons simultaneously for two seconds. All other settings but time and date are saved."
Aug 06, 2010 | Polar F11 Heart Rate Monitor
F11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
To Clear F11 Code after a power cut.
3, Power on
Thanks for using Fixya.
May 28, 2009 | Dyson Flowcheck CRO1 Front Load Washer
F11 key won't enlarge to a full screen
Can you place your mouse on an open area of the screen you would like to enlarge, right click the mouse and see if Lock toolbars has a check mark next to it...If it does, remove the check mark. Then go to View and click on Full Screen...Hopefully that will enlarge the screen.
If it does, click on the F11 button and see if it then shrinks the screen and click on F11 again to see if it enlarges it...Providing it does both, your problem could now be resolved...Either way, post back here and let us know.
May 25, 2009 | Computers & Internet
How to turn off the number lock button
Just press Fn+F11. An icon of a Padlock with a number 9 must be unlit for you to use the keyboard normally. If you need to activate the numeric keypad again, just press Fn+F11 again.
Apr 18, 2009 | Dell InspironTM 1501 Notebook
Polar F11 Heart Rate Monitor Logo
252 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
