Question about KitchenAid KGRA806PSS Gas Kitchen Range
Blown fuse inmy kitchen aid range
I was changing an igniter on my kitchen aid range and the wires accidently touched and spaRKED.tHE NEW IGNITER DID NOT WORK AFTER ITWAS INSTALLED. iS THERE A FUSE IN THE OVEN THAT COULD HAVE BLOWN?
    President:
  • KitchenAid Master
  • 1,922 Answers
If you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Posted on Jul 28, 2009
Random spark from igniter
it sounds like the wire that goes to the stove igniter is shorting out when you are using the oven.
Jun 09, 2014 | KitchenAid KGST307 Gas Kitchen Range
I was changing light bulb accidently unscrewed bracket . Spark ignited. Turn breaker off for 5min. Turned power breaker back on. Range not working. What can I do?
Un plug it. repair the unscrewed bracket, back to normal. Look for a fuse in the plug or inside the range near where the wire enters it, change the fuse.
Dec 15, 2013 | GE JSP26 Electric Kitchen Range
Kitchen aid convection range bake igniter stays on
Pull the igniter out and see if there is a short to ground on the wire. If none is found, replace the igniter. Here is the part to order.
Jan 20, 2013 | GE JGBP28 Gas Kitchen Range
Kgrs807sss put new igniter in, still doesn't work
Trace the wire from the igniter to the spark module. Make sure it is not broken or pinched between the frame of the range. If so, this can cause the problem your having. Hope this helps.
Nov 08, 2011 | KitchenAid KGRS807S Gas Kitchen Range
Model MGR5755QDQ The Range burners all working but the oven will not ignite. I purchased and installed a new oven igniter and now the broiler does ignite but when I set it to bake, I here the switch click...
Hello Steve,Sorry it took me so long to answer ya i missed the email notifying me of this i apologize!!So when you replaced the igniter was it for the broil or the bake?? And i wonder if by chance did ya accidently reverse the wires on the gas valve and inadvertently plugged the bake broil wire into where the bake igniter and vice versa i know that probably is not the case but no harm in asking.also does the bake igniter glow when set to bake...maybe ya want to recheck the wiring to the new igniter,what i believe you hear click is the relay on the control clicks so i think based on it clicking the control board is good and the problem lies in the igniter or gas valve.
Please respond and let me know if you should need further assistance.Thanks for using Fixya.GENE
Oct 30, 2011 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Igniter does glow and oven does not heat
Had same problem come up on christmas cold turkey yuk! What i did was swap the upper igniter for the broiler with the lower igniter for the oven and it worked so it sounds like the problem is the igniter you can do what i did to buy some time or just swap out the igniter with a new one. Good Luck
Jul 25, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Gas jets wont start they just make clicking sound
try oven if working gas valve system possible ok lift off covers to expose igniter looks like a little wire that arcs a spark to ignite gas clicking is igniter trying to spark ,clean area of debris if any, if no spark will need igniter adjuster /repaired or replaced and gas valve checked for proper function
Oct 19, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
HOW TO REPLACE SPARK MODULE ON KITCHEN AIDE KDDT207AWH0
It's very simple to replace. Pull the stove away from the wall so you can access the back components.
UNPLUG THE STOVE FROM THE WALL OUTLET.
The spark module is located on that surface below the stove top. Carefully note the position of the old module and label the wires so you can put them in the new module correctly. There should be 2 or 3 screws that are holding the old igniter module in place. Remove the screws, install the new module EXACTLY as the old one had been, and connect your wires. DONE.
Oct 08, 2009 | Kitchen Ranges
Wolf Range r366 - How do I replace the igniter
I have a Wolf Gas Range and initially my igniter incessantly sparked. I noticed that the igniter is cracked. Do I need to replace it and if so how do I replace it? The electrical wire to the igniter became disconnected; should sticking it back into the igniter cause it to work?
Jun 29, 2009 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Large burner only sparks for other values to light and won't light by its own switch
sounds correct, if it didnt spark at all and you had not replaced the igniter I would check that the wire from that igniter be followed to the other end to verify that it had not come unplugged at the other end.
On a new range I bought that igniter would not spark even though the others did and its wire was unplugged
Oct 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KGRA806PSS Gas Kitchen Range Logo
729 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
