Question about Kenwood DDX-512 Car DVD Player
Do you think is possible to put a external hard disc by usb plug
Do you think is possible to put a external hard disc to controle 20000 song with the ddx512 i have 120 volt ac plug in my car and i can plug the external disc in for powering the disc and plug the disc in the usb plug of my radio
Benoit
  • 66 Answers
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
Lacie by stark external hard drive is suddenly not recognised by my computer (always worked until now) and has a permanent red light. Tried all usb ports and restarting computer. Whats wrong?
have you dropped it? it could be any number of disc errors, two of the most common errors are caused by viruses and dropping. try putting the hard drive in the freezer for a day or so in a moisture and static resistant bag. just a possibly remedy, if that doesn't work, try removing the casing on the hd and setting it as a secondary drive after you plug it inside a desktop computer.
May 09, 2011 | LaCie 500GB Starck Mobile USB 3.0 External...
Extenal hard disc when plug in the USB the PC can't read
You may need to plug in an additional cable for power for the hard drive. If you have, make sure the hard drive itself is not broken
Mar 01, 2011 | Seagate Computers & Internet
My external hard drive, model #96300-40001-001 by SimpleTech isn't working. It is locked up and is making a clicking sound so the disc isn't moving. I was told to put it in the freezer (in a static bag)...
when a hard drive makes any sort of noise that sounds bad, it usually is. this hard drive has probably suffered catastrophic damage. i don't think you have any other option.
Feb 27, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
REQUIRE WINDOWS 7 DRIVER FOR IOMEGA SILVER SERIES 250GB EXTERNAL HARD DISC DRIVE. THANK YOU
The external hard-drive is "plug-and-play", and Windows XP/Vista/7 all support "plug-and-play".
Thus, it should automatically be detected by Windows.
So, what's your "real" problem? Symptoms? Error-messages? What happens? What does not happen?
Nov 05, 2010 | Iomega Silver Series External 250GB...
Do I need a disc to install
This is a external hard drive and no need for you to install any software to a computer in order for it to work , this is a plug and play device you just need to wait for the computer to recognize it after you plug it to a USB port and once its recognize its ready to use.
Jun 11, 2010 | Western Digital WD Passport 250GB Portable...
Computer doesn't detect drive
Hello
I had this problem a few months ago and i fixed it by following this steps.
Go to control panel.
Administrative tools.
Computer managment.
Storage.
Disc management.
Right click on you drive in the chart
Click on change drive letter
Change
Restart your computer and it should work.
Please rate this.
Best regards
Sep 25, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
USB Hard Drive
You cannot run a External Hard Disks (...that's what the User Manual say) It only reads Flash Drives, I have tried 8GB.
Oct 01, 2008 | JVC KW-AVX800 CD Player
Kenwood DDX-512 Car DVD Player Logo
129 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
