Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My hotpoint waher/dryer leaves water in the dispenser drawer after every wash any ideas please?
    President:
  • 704 Answers
Check to see if the unit is level, as the unit should be level front to back and side to side. If installed in a home, you'll need to check the manual for proper procedure to level and lock the leveling legs at the front and rear of the bottom of the machine. I find that having the front of the washer just slightly higher than the back of the unit is best for keeping the dispenser from retaining any water and liquids, but, again, check the owner's manual for their recommended leveling procedure.
If this is in an RV, then you'll likely need to confirm that your RV is actually level, consult your RV manual for procedure on how to verify proper leveling .
Posted on Jul 28, 2009
Detergent dispenser drawer leaks.
give the draw a good clean by pulling it out, and check the level of the machine
Mar 15, 2014 | Hotpoint Washing Machines
While washing water is leaking out of the soap drawer out of our 1st Addition Washer/Dryer Please help
Probably a soap blockage in dispenser, or washer is overfilling, or the drum is turning too fast on wash.
Check the dispenser to make sure it is clear of powder.
The drum should turn fairly slowly, or other wise it will throw water up to the diepemser if it is turning too fast.
Jan 11, 2010 | Hotpoint Washing Machines
Major leak after 20mins into wash cycle!
Have a good look at door seal., and see if you can see any hole or tear in rubber.If o/k, then remove rear panel, and watch whilst it is running, and see if you can see any sign of water coming from anywhere.
Make sure the water is not running down the front from the dispenser, which would suggest a blockage in the dispenser drawer.
These are the steps I would take first.
Also make sure the waste outlet is clear
Plz leave rating and any comment you may have.
Thanks..
Jan 21, 2009 | Hotpoint Aquarius WD640 Front Load...
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD71 washer/dryer
Hello farijl,
Welcome to Fixya,
You said, Water gushing from powder dispenser drawer. I have been told to take out drawer and put to one side. Looking into drawer space at back on right hand side there is a hole to be unlocked. It is so scaled up I cannot see hole. Can you help me or do you have an illustration fo what I am supposed to be looking at and unblocking ? Hope you can help soon. Floor is flooding every wash and cannot afford to get man out.
I found what you are looking for!
Below I will post the site for your WD71 User guide.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/531INST_016437770-02_WD71.pdf
If you scroll down to page 5 it will show you what and how to remove the transit brackets.
the dispenser drawer info is on pages 19 and 20.
My first post was incorrect about the bolt.
The American washers us a bolt!
Sorry.
You should be fine now and able to remedy this by your self
Let me know if you have any other questions.
Huuum
Please remember to leave a rating
Thank You
The detergent dispenser
will not close properly or is
collecting water?
1. Check the drawer is properly aligned.
2. Clean the dispenser drawer (see Care and Maintenance).
Oct 17, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Water coming out of dispenser drawer?????
The hose from the drawer is probably clogged.
Jan 24, 2008 | Hotpoint WMA31 Front Load Washer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
144 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
