Question about Garden
Scotts mower kohler command 25 motor bogs when mowing
JUST REBUILT FOR HEAD GASKET LEAK, DID BOTH SIDES. LOTS OF POWER RUNS GOOD. WHEN MOWER IS ENGAGED LOW BATTERY LIGHT COMES ON AND ENGINE ALMOST DIES THEN RECOVERS. HASN'T COMPLETELY SHUT DOWN ANY. THEN IT WILL BOG AS SOON AS I ENCOUNTER GRASS. DISENGAGING MOWER ALLOWS QUICK RECOVERY AND THE LOW BATTERY LIGHT GOES OFF. BATTERY CHECKS GOOD AND SYSTEM IS 13.5 VOLTS WITH MOTOR IDLING.
  • 218 Answers
Hi..my name is Keith..and it sounds like you have a binding somewhere on your mowing deck..i would check all the spindles .. pulleys and blades..and check the deck belt..it could have jumped a belt guard and it running on the outside of it..but just remember it has pulley brakes to slow the pulleys down when you shut it off..so..engage the deck without the engine running and check for the binding..i hope this has helped..if not..please write me back
Posted on Jul 14, 2009
How do I check for a blown head gasket
Dwayne, the third link talks about the signs and test for leaking head gasket. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
blown head gasket on kohler command pro 25 horsepower
How to replace head gasket on Kohler command
Legacy Kohler engine leaky head gasket repair
May 01, 2016 | Kohler Command V-Twin Horizontal Engine...
Kohler engine troubleshooting
I would be looking into the governor system... starting with the spring and then internal... but I would also looks at the connection at the carb... any play, damage ???
Sep 01, 2014 | Garden
Exmark 44
When you say 'going forwaed', is that while mowing or does it do it without the blades engaged or 'not mowing'?
Jun 13, 2013 | Kohler Engines NEW 25HP KOHLER ENGINE...
I have a bolens mower and just had the engine
Mine always slows down when I engage the mower drive. Since you just reinstalled the motor, I'd suggest checking the belt tension. Might be too tight.
Good luck
Apr 13, 2010 | Garden
Intek 6.5 HP in a Craftsman 21'' mulcher/bagger --loss of power--
No - 6.5HP is enough to cut 3" at a fast walking pace. I would suspect a blown head gasket.
Sep 26, 2009 | Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
14.5hp B&S ohv looses powes & blows white smoke on riding mower
This engine has a badly designed combustion head that causes premature failure of the head gasket. The removal of the overhead cam and head is relatively easy with the engine mounted on the mower. Just remove the hood before you begin. I had the same problem, same symptoms (white oil smoke, mostly when turning or on an inclide-=left side downhill) after the second season of mowing. Made me mad when I got it apart and saw the incredibly stupid head design. Replaced the head gasket and am into my second season with the new head gasket with no more problems but I expect it to blow again at some point. Poor engine design. Easily fixed.
Apr 01, 2009 | Garden
Garden Logo
370 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
