Question about Jura Capresso Impressa S90 Espresso Machine
I have a jura capresso S7. I am finding water in
I have a jura capresso S7. I am finding water in the underneath holding container after I make 2-3 espresso.. Is this normal?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
This is normal, after each cycle the brew unit will empty the drainvalve for excess water, this will ensure that the water used for each new cup is fresh from the watertank.
Posted on Jul 27, 2009
Message is in german and switches to series of numbers
Would it be possible to find someone who understands German to look at it for you? Maybe they could get it to change if they :spoke" to it in its own language.
Apr 24, 2015 | Jura Capresso Jura / Capresso IMPRESSA S7...
Jura S7 says fill tank but tank full
The brew unit is damaged and needs to be repaired.
Aug 18, 2014 | Jura Capresso Impressa S7 Coffee Maker,...
Water in disposed coffee container jura impressa z5
You may have to clean the unit using cleaning tablets, also there is a flap in the bay (remove the tray and use flashlight, sometimes it cakes up and moisture collects. Final thought is you may need to send it in to Capresso/Jura for service. Mike
Mar 08, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Drawer will not go back in for Jura Capresso impressa
For Jura F7 Series, "Tray Missing, can't put it back in". With a small flashlight, look in to the cavity which the tray and grounds container reside in. Along the right side above a slot to the end, you'll see a white micro switch. with a "Tooth Pick" simply press the switch inward (to the right) and hold till the machine cycles the Levcer / Flap up and out of the way.! Put your tray and grounds container back in and begin brewing!! -dh
Mar 17, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
I removed all the water pipes and do not know how to put in place so as to work,who can help me please with some detailed pictures or find the exact order details such insurance.
Hello
Come over me by purchasing any of my services advertised in FixYa. I've the exploded view of your Jura Capresso Impress S7. I can't send it to you by this window as it does not allow me to send PDF files by it. If you purchase any one amoung my service, I can get a link to you provided by FixYa, by which I can send the diagram and instructions by it. OK.
Dec 09, 2011 | Jura Capresso Jura / Capresso IMPRESSA S7...
I have a s7 Jura capresso expresso machine. It has been packed away for a year and followed the instruction as it was it was my 1st time (7 section 7 of the manual). I have filled it with water as per...
First, I'm not JURA technician. But I have worked on similar table top "Super Automatics" You should call your vendor or the MFR for service. Especially if it's still under warranty. There are no customer serviceable parts in this machine.
*** the following is for information only ***
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
PS: I've noted this tank also uses a water filter (which is probably dry after sitting around for a year as you mentioned.) you will probably have to flush out the air in the filter prior to this unit's pump to work properly. I found a youtube vid that may help:
https://www.bing.com/videos/search?q=s7+Jura+capresso+expresso+not+filling&&view=detail&mid=FA80FAE0243927C50056FA80FAE0243927C50056&&FORM=VRDGAR
Feb 11, 2018 | Jura Capresso Impressa S7 Coffee Maker,...
I bought a used Jura Capresso CoffeeTec 471. When i fill the water container and place the water container in the unit, it leaks water all over my counter. It seems the gaskets just can't hold the flow...
I had the same problem. I filled the water container and held it up for a while to make sure the two plunger/valves were not leaking. They held water well so I knoew it was probably not the tank. I called Capresso at 800-767-3554 and spoke to a tech. She asked me to test the water container and I told her I had already done this. She said then unless it was an internal problem it probably was the two seating valves that the tank fits into. She said the soft rubber gets hard over time. She sent them to me for free. I tried them today and when I took out the old ones they were very hard and the plastic cover was a little nicked. The new rubber is very plyable and when I put them in and seated the full water tank it made a nice rubber-to-plastic squeeking sound that let me know it seated correctly. It has been 2 hours so far with ten cups of water and no leaks. If you try this make sure you place the rubber grommet into the hole with the solid side up. It is shapped like an "n" and the open side goes down. Good luck.
Feb 18, 2011 | Jura Capresso CoffeeTEC 471 Coffee Maker
My jura impressa c9 coffee machine keeps tellnd me to fill beans when bean container is full
I just called their customer service 800-220-5701 with the same problem.
There's a point at the bottom of the chute where you can add ground coffee that tends to clog, especially if water gets in there. Access is from underneath - - remove the bottom tray and reach in - - it's not the hinged flap opening (that's the first thing you'll feel) but if you leave that closed and reach behind it, there's a silver-dollar sized area you're supposed to try to access and clean using a dry cloth. Once that's done you're supposed to try vacuuming from the top and then let it dry for a day or two.
Nov 27, 2010 | Jura Capresso Capresso IMPRESSA C9 One...
Jura Capresso Impressa S90 Espresso Machine Logo
309 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
