Question about Home
Water is running every 5 to 10 minutes
The Gmax valve vibrates a little and you can hear the water running and it runs from 2 to 5 seconds then stops, and in about 5 minutes it will do it again. You cannot see it flushing, you just hear the water running into the top tank. The flapper appears to be tight and no water movement in the toilet bowl.
We had the plumber out and he cleaned the Gmax, but it is still doing it.
Thank you,
Diana
  • 62 Answers
You might have a thermal expansion problem or the the valve is bad.
Make sure your pressure in the water system doesn't exceed 80 psi.
Open a faucet just a little bit and let it run. Wait to see if the toilet continues to do the same thing. If it does, replace the Gmax valve. You can use a Fluidmaster 400A. No need to get an expensive Gmax valve.
Posted on Jul 16, 2009
I have an Amtrol them x trol and I have significant humming through my home, when I check the unit I can feel it vibrating and putting my hand on it reduces the volume of the humming. The humming...
Most likely the humming is due to a defective or damaged check valve on your water METER and only translates the sound through your extrol expansion tank. The check valve on your meter should be replaced. The noise stops when you run water because the faster flow through the check valve opens it completely. Most likely you have a running toilet or dripping faucet that let's water seep through the check valve causing it to partially open and creating vibration in the bad gaskets on the check valve.
#1 have the check valve replaced
#2 find and repair the water leak
Dec 15, 2014 | Water Heaters
My Toto Carlyle toilet with Gmax valve CONSTANTLY runs...It runs for about 3 mins, stops, then runs for 3 mins, stops, and on and on this goes!!!! I need step by step instructions on how to fix the...
Sounds like your losing water out of the tank. check to see if flapper in tank has good seal (The rubber device that fits over the whole at bottom of tank, its attached to the handle by a chain or plastic rod). Make a mark when the water shuts off to reflect the water level watch the level of water over the time you specified. If the waterline drops the you definitely have a faulty flapper. Replace with new flapper which can be purchased at most hardware stores and DIY stores like Lowe's, Menard's, Home Depote. I hope this has answered your question, please rate the answer given. Good Luck and have a great day. Jeff
Apr 04, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
The gmax continues to run and won/t stop
if it worked fine and now it has stopped....then there is no adjustment that will fix it. If the fill valve is not shutting off you either need to replace the seal in the valve or get a new fill valve. If the water is leaking past the flapper you will need a new flapper.
Oct 20, 2009 | Toto Drake ADA Compliant Toilet with...
Dishwasher starts running for 2 minutes then stops
The first 2 minutes of the cycle is a pump out cycle followed by a brief pause then a water fill cycle.Make sure the water is getting to the water valve underneath. Check the water valve for power with a volt meter just after the pump out cycle. No power= bad timer or bad wire. Power = a bad water valve or no water present.
Jul 05, 2009 | Whirlpool Dishwashers
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Toto Drake with Gmax that oesn't completely shut off.
When you look in the bowl of the toilet, do you see the water trickling? If so then the flapper needs to be replaced.
Also, does the water run intermitentedly? As in every 2 to 5 minutes does the water kick back on to refil the tank? If yes then the answer is yet again the flapper.
Now if the water is constantly running then you can try bending the float arm (the ron that is connected to the big floating ball) down and see if that helps. If not then the next step is to replace the fill valve assembly.
Both of these together will run you about $20-$30.
Apr 29, 2009 | Toto Drake ADA Compliant Toilet with...
Ice maker continualy runs even when ice tray is full
theres aproblem here, I dontquestion that your hearing something operating, but if the valve is being activated, its going to fill with water( thats what it does!) so if your not geting water every few minutes something else is"buzzing"i would look elsewhere fro your problem doesnt sound like the valve
Jan 10, 2009 | KitchenAid Architect KBRA20EMSS Bottom...
Home Logo
770 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
