Question about Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarrius WMA 32 My element has gone how do I remove the old one?
  • Hotpoint Master
  • 3,463 Answers
Remove lower rear cover of washer, you will see the heater with 2 wires attached to it, and a thing that is called the thermistot, remove 2 heater wires, and loosen center securing nut, prize old heater out with a screwdriver or similar, fit new element and thermistor, reconnect and make sure it is tightened up securely.
Please rate my solution.
Thanks.
Posted on Jul 15, 2009
Hi, I have a fairly old hotpoint fdw80 dishwasher and think the thermal fuse has gone but i can't locate it in order to check if that is the issue or not. any help would really be appreciated. Thanks
They are often part of the element, so check for resistance in the element and this should tell you if gone or not. It might be worth checking if parts are still available for your model, as you say It is an older model
Jan 09, 2018 | Hotpoint Dishwashers
How to replace a grill element in a Hotpoint Oven?
remove old element by lifting it at the front and pulling it toward you.
replace with new element in reverse order.
Mar 23, 2013 | Hotpoint Indesit Bd32 Dy46 Ew74 2660watt...
How do I change suspension legs on Hotpoint WMA 62? The drum on my Hotpoint WMA 62 is bouncing around really badly on fast spin which disconnects an electrical connector turning the machine off. Both the...
Could be worn or broken dampers, or loose concrete balance weight.
This would cause the problem you describe.
There are 2 wieghts, one in the top, and one at the bottom of washer.
Check that the nylon locating pins are securly fixed in the damper legs, as sometimes they have been known to come out of socket.
Mar 22, 2010 | Washing Machines
The main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Hotpoint WMA 32 washing m/c noisy drum
is poss bearings or something stuck between the inner and outer drum
Jan 03, 2010 | Washing Machines
The thermostat has gone on my hotpoint cd00 tumble dryer and I need to replace it, I have ordered a new one, the only problem is I cant seem to remove the old one. Please can anybody help. Thanks, Kate.
Depends on which thermostat you are talking about, as there is more than one thermostat.
2 thermostats are located on the heater element itself, located at bottom rear of dryer, if you cannot see the stats, then you need to remove the heater, and they are located behind the element, be careful, as it is very easy to break the element supports, and then you will need a new heater.
Trust this helps solve your problem, And GOOD LUCK.
Nov 26, 2009 | Hotpoint Dryers
Water not heating or drying
It is possible that the element has gone, \even after such a short period of time.
If it is only 6 months old, then you need to contact Hotpoint service department, and get it fixed under the guarantee, do not try to fix it yourself,, as you could invalidate the guarantee.
If you look inside your user instruction hand book you will find the telephone number you need to ring to get service.
Please rate my fixya solution.
Thankyou.
Feb 01, 2009 | Hotpoint Dryers
Hotpoint WMA 32 broken wires on Motor?
This has to be the pick up for the fast spin as any other would disable the motor.
Dec 20, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
116 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
