Question about Car Audio & Video
Bridging Is a Kicker DX 700, 2 channel amp bridgable
  • 20 Answers
Its a mono block amp.ALL amps are bridgable but to a certain degree..
Posted on Jul 15, 2009
  • 33 Answers
Yes and no lol. I sold that product about three or so years ago. That amplifier is whats called a mono amp. The outside shows two channels but they are still tied together. Think of it as a hose with a Y on it so two lines can run out from it. Its still the same amount of water whether you use both hoses or not. So bridge it if you want to but it will for looks and looks only. Note that amp is only two ohm stable so be careful what woofers you use. You will want two single 4 ohm woofers for a regular instalation. DO NOT USE Dual 4 ohm speakers Good Luck
Posted on Nov 17, 2007
  • marcus lara May 20, 2013
    1 of the amps has 2 channels and the other has 4, but i need to know how to hook up the battery, ground, and remote wires?
How do you connect wiring to bridge an adcom gfa 5300?
The manual does not specify a bridging option.
http://www.audioreview.com/cat/amplification/amplifiers/adcom/gfa-5300/prd_116265_1583crx.aspx
"Weaknesses:
Not bridgable."
Generally an amp that IS bridgeable uses the positive speaker terminals and some switching method to tell the unit to run as bridged. This is NOT a recommendation to try it on the 5300.
Aug 02, 2011 | Adcom GFA-5300 2-Channel Amplifier
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    Dec 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
    • Amplifier Type: Dual Channel
    • Bridgable: Bridgable
    • RMS Power at 4 Ohms: 150 W x 2
    • RMS Power at 2 Ohms: 300 W x 2
    heres a link to a stats page for the zr600>
    http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
    Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
    WHATS THE WATTS ON THIS AMP
    Feb 04, 2010 | Kicker ZR600 Car Audio Amplifier
    Can i bridge rsd60.1 ser#069243867003
    Negative a any amp that is 60.1 or 1500.1 whatever it is .1 is a mono amp and needs no bridging. Some mono amps are set up like a 2 channel but they aren't bridgable they just add more options for wiring each individual sub to the amp...
    Dec 11, 2009 | Phoenix Gold Car Audio & Video
    Kicker 8 inch 4 ohm subwoofer 200 watts rms?
    Max 200 W. You could bridge 2 channels of a 4 channel amp (or get a 2 ch amp and bridge it) and connect the sub. Bridging = connect + of sub to + of one channel, and connect - of sub to - of *other* channel. Check amp manual for instructions.
    Don't get a mono - most are 300W or more - might burn the coil during loud passages.
    Jun 22, 2009 | Car Audio & Video
    Subwoofers
    This will depend on the amplifiers capabilities.
    I will give 2 different scenarios.
    #1 Stereo configuration
    If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
    Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
    #2 Mono Bridged mode.
    If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
    Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
    So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
    For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
    Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
    Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
    Bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
    I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
    Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
    Mar 05, 2008 | Kicker 01C8VR4 Car Subwoofer
    Is it not bridgable
    This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
    Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
    Car Audio & Video Logo
    357 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
