Question about Pioneer DVR-640H DVD Recorder/HDD Recorder
The Hdd displays "repair err" too.
Did you find a solution?
I have an error code HDD ERR
When your HDD (Hard Disk Drive) does not work, the computer would like a recovery disk, or with windows the Windows disk will do. If only the OS has some damage windows will see so and ask, should I recover the OS already on the HDD. If you choose that opting, the CD will try to recover everything.
If your HDD is really defect and can't be recovered by the OS, toy have to replace the drive and setup the computer again. You have lost all data and all program m's on the HDD, so I hope you have a backup of at least all your data.
Good luck
Jul 21, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Err message on D70 and clock flashes
D70..err display...problem with the loader section switch,rotating while loading is open,so get it repaired.
Mar 07, 2010 | Nikon D70s Digital Camera
Flashing err 16 after trying to copy from hdd to dvd.will not reset.help
Pressed display button on remote control,error went and not seen again.
Jan 14, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
1999 Chevy Lumina won't play any CD, display reads 'ERR'
Hi:
Unfortunately, the ERR is a disk read error, and usually caused by the laser being out of alignment. It seems in my experience that An aftermarket deck is a cheaper solution than having it repaired.
Nov 20, 2009 | 1999 Chevrolet Lumina
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Panasonic dmr ex75
HDD ERR is quite a serious error, as it means there is a hardware problem with the internal disk drive. You could try switching off the unit and disconnecting the mains cable overnight, and trying again, but really this will need to be a call to an engineer.
If your unit is still in warranty call them now to arrange a fix. To find your local warranty centre, go to your regional Panasonic website, and look under Customer Support
Nov 21, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Pioneer DVR-640H DVD Recorder/HDD Recorder Logo
76 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
